Results 1 to 8 of 8
- Jan 2008
- 6
April 16th, 2008 08:21 PM #1Mga sir bibili na sana ako ng mags kanina but i noticed na lahat ng
Aftermarket wheels na gusto ko has a larger hub opening than the stock hub size.
Ok lang ba yun? May mga gumagamit ba sa inyo ng "hub rings" and san nakakakuha nun?
Di ba masama kung puro stud lang ang humahawak sa weight ng car? thanks again
April 28th, 2008 11:53 PM #2
I just had hub-centric rings fabricated at Autoplus. They cost me PhP2000 for a set of four.
The center spigot should mount flush with the wheel's center bore as it should carry the weight of the car, not the wheel studs. The studs were never designed to carry weight, so if they become load-bearing structures they can shear off the hub assembly due to the strain. You can say bye-bye wheel then.
Here is the wheel on my car without a hub-centric ring. Notice the gap between spigot and center bore.
Here is the wheel after fitment of a custom-fabricated hub-centric ring. The wheel now sits flush with the spigot.
Lastly here are the rings themselves.
April 29th, 2008 05:47 PM #3
2K? medyo mahal siya ah.
di ba pwede sa ordinary
machine shop magpagawa?
April 30th, 2008 11:45 AM #4
Pwedeng-pwede sa suking machine shop basta alam nila yung measurements.
- Jan 2008
- 6
May 3rd, 2008 09:48 AM #5sa c.c. barleta sa may sucat paranaque 200p each. pero mas ok siguro sa autoplus kasi mas marami nag papagawa ng hub rings dun.
- Jun 2004
- 207
- Nov 2014
- 48
November 23rd, 2014 09:21 AM #7
- Nov 2014
- 48
December 5th, 2014 04:06 PM #8nagtanong ako sa barleta, para sa montero 2k daw ang isa.
sa autoplus naman, sabi sakin nung unang kausap ko 3.2k daw estimate nila sa mga nagpagagawang montero. tapos dun sa sumunod na kausap ko naging 2.5k naman ang isa.
ayus.
