Results 11 to 20 of 29
April 18th, 2014 05:40 PM #11
For a mud tire, mahaba na din life ng STT. Our off road pals have them and attest to their durability. But as they say, actual results may vary.
Posted via Tsikot Mobile App
April 18th, 2014 06:11 PM #12
like wise sir, baka STT na din bilhin ko pag nagpalit ako nang tires. 1st choice ng wife ko is an AT3 but I said oks lang mag AT kami but naka 20" rims then the problem is that AT3 has limited sizes on its 20". Kaya I said better na mg STT 285/70/17 nlang ako w/a 2" lift since i'm living in the province (Agusan del sur) naman, I could use some ground clearance.
April 19th, 2014 02:41 AM #13
a cousin of mine who used ST, STT and ST Maxx on his pickup told me that STT wears out faster of all the 3 models.
according to cooper, ST Maxx last longer due to its Armour-tek rubber compound. but it's the most expensive among the discoverer models. in australia, ST Maxx owners have used them up to 60k+ kilometers.
- Jun 2004
- 476
April 19th, 2014 06:21 AM #15I have an AT3 on one of my rigs (265/75/16). Got it for P7,800/tire in 2012. Clocked 32k kms and so far so good. Parang Nitto din ang tibay. Will get a set of STT for my Samurai (235/85/16) for long drives. Sayang Simex sa road madali mapudpud.
April 19th, 2014 07:37 AM #16
April 19th, 2014 07:47 AM #17
Mas madali talaga ma pudpud ang STT compare sa ST Maxx sir dahil the STT has more wider gaps in between the thread than the ST Maxx. The ST Maxx is more in between the category of MT and AT tires. And kahit anong Manufacturer/Brand, the MT tires will always wear out faster than that of its lesser aggressive looking type of tires.
April 19th, 2014 08:01 AM #18
- Jun 2004
- 476
April 19th, 2014 08:04 AM #19*glen manikis here you go. Its on my Gen 2.5 Pajero.
April 19th, 2014 08:12 AM #20
*paj4x4,
saan mo binili ang AT3? need ko kasi 2 pcs 285/75/16 ST ngayon. 2 pcs lang ang available sa dealer dito sa amin. ST ang gusto ko ikabit sa ranger T6 dahil +10 offset ang rims na nakuha ko. sa ST at least side wall lang ang lalabas at under ng fender pa rin ang thread.
kapag STT at ST Max, naka luwa na ang tires at hirap maglinis lalo na sa tag ulan
Did some independent research and decided to go with the white pearl crystal.... para maiba naman. ...
