Results 1 to 7 of 7
- Jun 2010
- 64
June 14th, 2010 11:33 AM #1Hi fellow Tsikot.com members, newbie here..hope you can help me out..
Whats the difference on ride, fuel efficiency, "hassle" , expenses when using 17s and when using the stock mags.
Thanks
June 14th, 2010 11:43 AM #2
ride -> mas matagtag because you use low profile tires, manipis kumbaga.
fuel efficiency -> not so sure.
hassle -> wala naman esp. if you're willing to spend a day scouting around for rims and tires
expenses -> syempre much expensive pag nagpalit ka pa ng rims & tires.
handling -> it would be better since the width of the tires will be much wider than stock
June 14th, 2010 11:58 AM #3
hi d_rookie,
i changed my tires to 17" also (215/45/17).
di naman sya matagtag. my mazda 2 has stock rims and tires and i do not notice na mas matagtag yung coolbear ko na naka 17".
but more than anything else, a 17" will definitely give your car a more "aesthetic" look. it more than compensates kung meron ngang effect ito sa ride and handling ng kotse mo.
- Jun 2010
- 64
June 14th, 2010 11:58 AM #4
June 14th, 2010 05:55 PM #5
Some cars then to go higher when replaced with bigger rims. Kaya don't go far, it might require you to lower it soon enough or else it will look ugly.
Best rims for the City 04 ? The current 1.5V Jazz rims. They're 16's so it won't be compensating the ride.
- Jun 2010
- 36
June 24th, 2010 02:35 PM #6Medyo matagtag nga ng konti pero baka hindi mo na mapansin kasi yung jazz namin stock pero ang tagtag. Pag nag 17's ka sir, medyo kailangan mo mag-lowered kung hindi lalong papangit yung dating. Ako 10 years na akong naka 17's e.. Medyo mahal nga lang yung goma. Kung ayaw mo mag-lowered sir, I think you should remain stock na lang or upgrade lang nung pang jazz 1.5 na 16's parang sinabi sir renzo para stock look pa rin.
July 19th, 2010 10:41 PM #7
ganda 17"........ had my aria using 205/40/17 mas ok naging ride compare sa 15" ko last time..... baka psychological na lang
Na lock ang Gcash ko, need verification pa and kasama sa list nila ang philsys ID paper, but when I...
National ID Law
