sir, magkano po ang mazda r2?
In my case, Php46,000 andito na sa Iloilo, siguro, mga 38,000-40,000 yung bli ng cousin ko sa blumentrit. Other than that bumili pa sya nang fuel pump and air cleaner.
Problema ko ngayon yung registration kasi wala pa ang papeles ng engine na galin sa LTO (Quezon ba yan or what), end of the month pa daw makukuha.
marami pala ang fitting job na kailangan kung gas to diesel engine change. a mechanic here said its drop-fit from kr2 to mazda r2. advised me also that its better to change the kr2 engine if kelangan nang i-overhaul, mas quieter daw ang mazda than kia. kumusta na ang sporty during roadtest sir?
i heard some if not most Cebuano sporty owners changed their engines to mazda r2, try to browse buy-n-sell sights baka masuerte ka may mga sporty owners disposing their already tuned-up sporty.
remember, most of this as-is sportys have been sitting without engine start in korea for some time before being shipped here.
i got mine at 180k as-is, with papers na, so no worries.
*here are the things i changed in my as-is sporty:
-timing belt
-all water jackets(kinalawang na maybe due to long stand-by in korea)
-all of the cooling system hoses(most if not all are already brittle resulting to leaks - resulting to overheat)
-master break system
-break pads/shoes
(did this one after anotherif i did this one time, mas naka mura cguro dahil isang baklas lang sa engine area hehe
some things you should look out for when buying (good if you have a mechanic background or bring a mechanic friend):
*engine
*water pump
*alternator
*fan(kung naka-lock na sya)
*usok, as long as black/dark wag lang white
*walang noise sa drivetrain
*suspension coils
*power steering
*go for manual Xmission
- if your going to cebu or cdo, do a change-oil/greasing/washing(with engine wash) and drive around a little bit to see its performance before the road-trip home.
bottom line, this is a very nice and reliable suv, been all around zampen with this babycurrently running with an ave. of 12Km/Li (with aircon-on). still needs to do an injector tuneup/adjustment?? - might give a little to its fuel efficiency. good luck
ok naman yung takbo nya, pro hindi ko pa ma labas-labas sa bahay kasi hindi ko pa ma register (change engine). perfect yung mounting ng engine, may kaunting modification lang sa steering shaft at sa lalagyan ng battery since you need a bigger battery if the engine is diesel, yung ma busisi yung sa transmission nya. Talagang hiniwa yung sahig malapit sa tranny just to adapt the new transmission.
Ang una-una kung titignan yung fuel consumption nya. Hopefully I can register before this month will end.
Kalabas lang ng talyer kahapon. These are the new images I have:
am a newbie here.. am planning to buy a kia sportage short first gen. ano ba ang actual overall length sa unit na ito including the spare tire? of course excluding bull bar if any. ayoko kc ng may bull bar. ang nasa specs kasi sa kia site is bumper to bumper length dimension lang which is 167.1 inches. Sa may mga ganitong unit na, pls help. I was wondering kasi if this unit will fit to my car port which is only 169 inches. Thnx. GOD Bless.![]()
Hi Guys!...
I'm from Cebu!... It's nice to see that this page is active for 1st Gen Sportage OWNERS!... Mine is Short Bodied-local unit Diesel non-turbo... So far the following are my MODS.
1. Painted it from red to metallic brown
2. Grill
3. Installed Wheel Spacers
4. 235x75 wheels
5. Replaced steering wheel
6. Installed MP3 headunit
7. LED Panel Lights
8. Installed SIMOTA Cone Filter
9. Installed Trenz Muffler
10. Installed 2" spacers for Rear Coils
Next Project... Custom Fiber Sticer for the Hood!
I will Post PICS for you guys as soon as my cam is ready!...
Just wanna ask how do we fix the drivetrain... mine is noisy...
Thanks!
ShuaBOX
hi huys..
ask ko lang po kung magkano ang price range ng sportage ngayon 1st gen plano ko po kasi bumili. at ano po ang fuel consumption nito?
sir, magkano ang grills? marami po bang option sa cebu?
i also want to know about the drivetrain noise. mine was particulary noisy when on 3rd gear. regular greasing helped some, but you can still notice noise during acceleration when the rpm is <1500.
1st gen sportages in Zamboanga ranges from 200k-270k. mine is a 2.0l diesel Kr2 non-turbo engine, averages 12km/liter with aircon. planning on doing the fuel injector tuneup, i hope it improves the fc.hi huys..
Good Day everyone, I have already register my Sportage last first week of May, as I have observe the new engine, medyo ma tipid siya compare sa original gasoline engine. I think the fuel consumption is about 1li per 12km. In my observation, its really worth na I have change the engine considering the price gap between diesel and the gasoline now a days. Here in Iloilo, diesel price 48.xx per liter while the gasoline premium fuel is at 61.xx per liter.
Btw, I would like to ask about the sportage spoiler, saan ba maka bili niyan? Thanks
Marami dito sa cebu... or if you know somebody in a fiberglass shop you can fabricate one....
gud pm....im planning, still planning, on getting a kia sportage..
ano po ba mga pros and cons nito?
anything i should look for?
tnx
if your planning on getting a second hand 1st gen sportage 2.0l diesel esp those that came from korea, here are some notes:
cons - those sporty's have not been used or even started for several years say 3-5 years.
*no cooling system water circulation - watch out for all rubber hose wear esp the one at the
waterpump- need to change them all coz they are the primary cause of overheating.
*the temperature sensor does not work very well in the philippines and is a cause of overheating,
have it cancelled and lock the propeller.
*wear of all belts due to underuse. change all belts especially the timing belt.
*change all lubricants and grease.
*head gasket wear maybe due to underuse -cause of overheating. at the first instance of overheat, have the head gasket changed.
*Not so good aircon system. i'm planning on cancelling/bypassing the heater coils to lessen/eliminate the heat into the dashboard. last con to tackle hehe
pros -
*cheap for its class
*no major problems after all concerns for the cons have been addressed. (minor problems are
regular maintenance, tire change, battery life, break pads and the like i mean hehe)
*good fuel consumption
*fast and powerful small diesel 2.0 engine
*engine parts availabilty - also compatible with mazda r2
*power everything.
i have one and i love it:loveshower:
Mga masters pa tulong naman po.
Ano po ba ang regular engine temperature ng Kia Grand Sportage 1(st gen) para mag function yung Temperature Sender?
Recently na sunog yung Heater Module sa Control Unit, dahil yung temperature sender ay dipala nag pa function ng ma a yus. Bali gumagana parin yung heater kahit uma andar na ang makina, at umi init ang dalawang malaking wire sa relay ng Control Unit, in fact medyo sunug na ang mga socket plug sa relay.
Pati ang glow plug ay tatlo ang busted at pinalitan ng bago ang apat.
So pinalitan ng surplus na Control Unit at saka Temperature Sender.
Ang problema, nag pa function lang ang Temperature Sender pag nasa pangalawang guhit na ang temperature nya. Ng inobserbahan ko kanina ng umaga naka idle ang engine mga 6 mins. Di parin tumataas yung temperature, na sa pinaka last o mababa na guhit lang, because of this umi init ang dalawang malaking wire sa relay ng Control Unit, kung kaya ito daw ang naging dahilan ng pag ka sunog ng IC sa lumang control unit. Pag pina patakbo na ang sasakyan it takes around 5 mins. bago pa mag function yung temperature sender, at this time nasa 2nd guhit na ang temperature at pata as na.
Pero pag ma init na yung makina sumasabay sa pag off ng glow symbol yung temperature sender, so nag tri trip yung relay.
Advise sa akin ng electrician ipatangal ko daw yung thermostat para continues daw ka a gad ang flow ng ma init na tubig sa makina at mag function ka agad ang Temperature Sender. Tama bato?
Ang worry ko lang baka masunog uli ang Heater Module sa Control Unit at ma sira agad ang glow plug, dahil medyo matagal bago umakyat sa pangalawang guhit ang temperature ng makina para mag function yung Temperature Sender (6 mins sa umaga pag naka idle ayaw parin, 5 mins pag tumatakbo na).
Tulong naman po mga expert.
TIA![]()
nakabili na ako ng sportage short surplus american express model 1999 4WD, Mazda RT engine, turbo diesel intercooler. so far so good. cool engine and tranny. body and chassis in good condition except for some minor concern which needs servicing (eg: power side mirror, fuel lid cable). as of now am on familiarization and minor maintenance stage considering this unit is mothballed for quite sometime in Korea. it's safer to have it on top condition first before rolling to the field.
Im Cebu base now and ang dami ko nakikitang Kia Sportage na Diesel... and im quite interested.. Hindi po ba mahirap yung mga parts neto? ano po ba brand ng aircon compressor neto?
calsonic ang nabili ko nun nagpalit ako ng compressor, meron din zexel and korean made doowon
hi guys, kakakuha ko lang ng sportage 96, tanong ko lang kung meron ba kayong kopya ng Kia Sportage 1996 User's Manual? kung saan makakapag download.
and papano ba paganahin yung 4wd niya?
