Page 4 of 8 FirstFirst 12345678 LastLast
Results 61 to 80 of 154
    #61
    ok ba ang surplus na sportage 1st gen? i mean engine, aircon, coz im planning to have 1 but endi ako acquainted sa diesel engine kung ano ang mga dapat i check before having 1. and also sabi kasi nang iba na hassle daw ang sportage kasi surplus but i don't take them cause i know they were just stereotyping the vehicle. bu then again i could be wrong.. so, in need po talaga ako nang expert advice^^
    Jun 2009
    #62
    mga sir, mayron akong 1994 sportage na diesel engine..ok tlaga ang takbo nito..tanong ko lng, r2 ang engine nto..original engine ba nito tlaga?? tipid sa krudo..hehe..
    #63
    hi! were planning to buy grand sportage surplus from korea. ok ba ang unit?ang makina?iv heard and read that madali daw mag overheat....
    what will we check if were going to buy one?
    Aug 2009
    #64
    mga sir,tanong ko lang po kung san nkkbili ng mga parts & accesories nung sportage.i hav sportage 96 converted 2 diesel.malabo n head light,nplitan ko n rin ng bulb malbo p rin.ska nalaglag ung left signal lamp assy ko..hirap mghanap ng parts e.badly needed ur help mga sir..thanx
    #65
    Quote Originally Posted by devon_red View Post
    Kia dealerships can help. I got most of my parts to maintain my sportage sa kanila. Also Goodgear in Pasay gets a lot of recommendation from owners of Kia vehicles.
    hth.
    #66
    Ang dami dito sa cebu ng parts and accessories ng 1st gen sportage. Andami kasing sportage dito sa cebu, lahat ng color represented. lol
    Aug 2009
    #67
    I have one sportage ang engine is kia- RF intercooler turbo, ang tanong ko is saan ako makabibili ng original cylinder head gasket. please help me? any recomendation na maiibigay sa akin i appreciate it very much.
    Aug 2003
    #68
    Quote Originally Posted by Diesel_Torque View Post
    Thermostat is very important for the engine to maintain the ideal engine temperature, sa pabago-bago na temperature ng Engine apektado ung performance thats why lahat na sasakyan ngyn may thermostat.
    Mostly for Japan and Korean design vehicles pag dinala d2 satin nag-ooverheat talaga pag tagal due to the high temperature design Thermostat parang napupundi ung Thermostat na design sa malalamig na lugar pag dating d2 sa Tropical country. kya dapat palitan sya ng Low Temp Thermostat which is madali mag-open from 65C to 75C fully open na, ung design sa Nagyeyelo na mga bansa is 80C to 90C pa ang kailangan pra mag fully open ung Thermostat which also pra din sa Heater nila sa loob sasakyan.
    Hindi ako bilib sa Machanic na nagsasabi na hndi na kylangan ng Thermostat d2 satin kc daw mainit na d2 satin, pra sakin mas malamig at maginhawa ang makina pag may Thermostat lalo na sa mga Automatic kylangan may Thermostat pra sa cooling system nung ATF.
    Saan makakabili ng low temp thermostat? Meron ba niyan dito sa Pinas, yung specifically low temp type? Kasi baka yung mga binebenta dito yung galing sa surplus, which means yung chinop chop na makina, which would mean the original high temp thermostat.
    Aug 2003
    #69
    ang mga kia spare parts stores walang low temp sensor, they only have 1 type, which is the same as what is installed in the surplus sportage. They pointed towards kia casa shops. Tinawagan ko, wala rin sila, they asked me to call back, maghahanap din daw sila.
    Aug 2009
    #70
    good day mga bossing i have a plan to buy a kia grand sportage korean surplus.saan ba mas mura sa cebu or sa cagayan? coz im here in dumaguete city.and also give me a aviced before i buy. ty.
    Sep 2009
    #71
    concerning po sa pag papalit ng gulong, eto po baka makatulong;
    Why is this important?
    Matching the combined wheel and tyre diameter is important as it will ensure your ride height and speedometer readings don’t change drastically. An example of this would be fitting 17″ wheels to a car that has 14″ wheels as standard, there are three main consequences:
    1. the ride height will change, the car will be further from the ground.
    2. the top speed will increase slightly and the speedometer will under read.
    3. the car will acceleration slower.
    Read on to see the reason for this in detail.
    Tyre Size Guide
    Ride Height
    Take the default example in the flash tyre size calculator above, here we have a stock tyre size of 165/55R14 and a new tyre size of 215/45R17. There is a total difference of 8.82cm in the two wheel and tyre diameters, if we divide this by two we get a difference in radius of 4.41cm. If we ignore tyre pressures and the effects of adding larger, wider wheels to suspension geometry; then this is roughly how much higher the car will be from the ground.
    Speedometer
    Then there’s the speedometer, a cars speed reading is usually taken from the transmission and is set based on a number of predefined constants. When you change your wheel and tyre combination you are taking one of these constants and making it variable. The speedometer does not know the new value and so continues to read based on the original wheel & tyre size. If you look at the above default example again you will see that with a 215/45R17 wheel and tyre combination there is a difference of 16.4% in the speedometer reading over the stock setup. As you can see, at 60mph your speedometer should actually be reading 69.9mph!
    Acceleration
    If we fall back to the default example again, the 215/45R17 wheel and tyre combination has a larger overall diameter by 8.82cm. A larger diameter has a greater rotational inertia which requires more energy to accelerate. Or in other words: the bigger the wheel, the slower the acceleration.
    It should be noted that putting a bigger wheel and tyre combination on your car does not reduce your cars power. Your cars power remains the same; however it takes more force to turn your car’s wheels resulting in slower acceleration.
    paki check na lang po sa link na ito: http://www.kouki.co.uk/utilities/vis...ize-calculator
    sana po makatulong.
    more power to 1st gen. kia sportage owners!!!!
    Jan 2011
    #72
    Elo. ma walang galang na sa inyo, have just join this forum. Im from ilo2 and currently owning a kia sportage 97 2.0 gasoline short body.
    We bought it in manila last 2005 pa, and from then on, we have a lots of problem, overheating, tie rod end replacement, engine sensor, hard starting, power windows not perfectly working, have change alternator etc.. last july 2010 i have it top overhaul, fuel comsumption nya is 1Li/7Km. considering the price of gas now, na pupunta lang yung budget namin sa pag maintain ng sportage.
    Until last september, na overheat sya ulit for the reason me leak yung radiator nya, after that I decided to junk it in our garage. This month I decided to convert it using mazda R2 2.2 diesel engine and this saturday darating na ang engine nya. We bought the engine sa blumentrit through my cousin.
    I try to post dito ang progress ng conversion nya. so hopefully ma prove ko yung mga na ki claim dito na ma kaka abot ito ng 1lit/16km ang fuel efficiency ng diesel na sportage. given that soon my kia sportage is converted into diesel engine. PEACE
    Jul 2010
    #73
    sige bro, goodluck na lang...sayang naman yang Sportage mo kung ijunk mo lang....
    Jan 2011
    #74
    Good day mga kapatid, ito na yung sportage ko.. kinukuha na yung orginal na gasoline engine at ang mga picture ng mazda r2 diesel engine na ipapalit ko
    MAZDA R2 Engine
    Jan 2011
    #75
    Good day everyone, these are some of the many issues regarding the conversion. First is the tranny: The Mazda R2 transmission is shorter than the original.
    Heres the new tranny..
    Heres the Original Tranny..
    And here where the original tranny is longer than the new one...
    Aside from the length issue of the transmission, there are some noticeable differences.
    So the propeller shaft will spend a day or more in the machine shop. The length of the rear will be increase and the front (4wd) will be decreased.
    I'll try to update on the progress of its conversion and hopefully I am in the right thread..
    #76
    Mga Bossing,
    I'm from batangas!We're planning to buy a sportage!question lang po ok ba bumili sa CDO or cebu ng sportage surplus, reasonable kasi ang prize nya!Ano po mga dapat i check na documents para safe i byahe ng manila!
    thanks,
    Dec 2010
    #77
    Quote Originally Posted by jon2tan View Post
    Mga Bossing,
    thanks,
    Cebu is cheaper than CDO. Sa CDO, galing din sa Cebu ang mga units nila. But mostly they are "as is" basis. Although meron din ni repaint yung iba. Just look for leaks around the engine at siempre kung mausok ba sya. Karamihan ng mga ito ay hindi na change oil mula pa sa korea, kasi as is nga. Sa papeles tingnan mo lang kung kumpleto, pero sa pagkakaalam ko, rehistrado na ang mga ito.
    Jan 2011
    #78
    to continue the story of my kia sportage 1st gen conversion (my apologies for not updating my previous post immediately) here are some of the pictures during the course of work..
    medyo ma busisi yung pag install ng tranny, to make it adapt, they have to tear the floor a little bit as shown in the first picture. Then the front wheel drive is obstruct by the front seat floor, then they have to modify that area to make way for the front wheel propeller shaft.
    the steering wheel shaft was also block by the aircon compressor. By the way the new engine mount perfectly.
    Now what they did is also open that area to make way for the steering wheel shaft.
    Then besides the front wheel on the driver's side they had some modification also for the steering wheel shaft.
    Jan 2011
    #79
    then finally they have installed the tranny, but the 4wd stick and the tranny stick was reversed, somehow they manage to install in a way to preserved the form. But of course the front seat floor now is a little bit bulky as mention in the previous post.
    Some of the pictures in the last stage of conversion.
    Jan 2011
    #80
    Recently we bought 11 plates motolite gold, the previous battery with is only 9 plates cannot be used with the new engine.
    Hopefully this week we will be able to have a drive test but this morning, they have able to start the engine and it sounded ok. The air intake was not yet installed but I believed it will be install easily. Another thing is that, the air condition needs to be lined anew since the new compressor is located in the drivers side. The cost of the job is not included in the conversion.
    They started that work since the last week of January 2011, the conversion takes a little longer and hopefully (even its raining here in Iloilo), it will be done before this month (march) will end.
    PS: The registration might be expensive because of the new engine.
Kia Sportage (1st gen)
