Results 1 to 11 of 11
    Apr 2004
    good day tsikoteers! i need to replace the front shocks of my besta, i've canvassed these:
    kayaba fluid type 650 pesos *
    kayaba gas type 900 pesos *
    monroe fluid 650
    monroe gas 800
    which do you think will be best for the van?? i'm thinking of gas but worried about the ride becoming harsh....
    btw, the vans front suspension system are Torsion bars..
    tia!
    well matalbog naman talaga ang vans in general. if you dont haul people or cargo sa likod lagi mag fluid ka nalang, pero if you do, gas will offer you more headroom pag nalubak.
    KYB gas. I tried KYB fluid pero ang bilis mag-overheat resulting in soggy shocks. Maybe because of the loads I used to carry on my Kia.
    Gas shocks also make the van handle better..
    Apr 2004
    thanks! i'll use the gas type na nga lang...
    follow up question, are monroe shocks generally stiffer than KYB's???
    Haven't tried monroes. But all the Pajero/Montero guys who did at 4x4wire, hated them so ayoko na mag-risk pa.
    Apr 2004
    thanks for sharing otep! its KYB's then..
    My own rule from experience, gas type don't mix well with leaf springs.
    Quote Originally Posted by Ungas
    ganyan pa naman sa xind..... so ano dapat fluid pag naka leaf spring?
    Apr 2004
    same here, my gen1 pajero had gas all around and the rear is so harsh if not fully loaded...
    buti na lang TB yung harap ng besta.
    Quote Originally Posted by x-wind
    Fluids are more confortable for leaf sprung type. Nung naka-gas type ako sa previous rides kahit lagyan ko ng 50kgs load di kinaya yung tagtag.
    Apr 2004
    i installed KYB gas-a just the other day ago and drove to Nueva Vizcaya the next day..
    The ride was great! gone are the frequent nose dive and the boat like ride i usually experience in the van.. handling was way better, i found myself driving faster on Dalton Pass twisties with confidence! The ride now is FIRM but no harsh..
    thanks to OTEP, i got convinced to try out KYB's gas shocks.. i'm very satisfied with it.
    btw, otep, did you replace your rear shocks in your besta as well?? will a gas type be harsh since its leaf sprung?? most vehicles does.... but in the besta's case.. the rear seems soft..
    medyo OT, you guys have any leads on finding a workshop manual for a besta or for an R2 engine??
    TIA!
advice needed: what type of shocks to replace in besta
