Results 1 to 6 of 6
    Feb 2011
    Mga Sir,
    Ganito po nangyari, yung drain plug po ng makita ay mayleak, ayun sa brother ko, pinapalit na yung drain plug pero nagkulang yung oil (econo oil ang gamit ng trooper from casa), ayun sa mekaniko ok naman daw yung castrol oil na pandagdag kaya ayun dinagdagan, bale less than a half liter po naidagdag,, tanong ko po, may effect po ba ito sa fuel injectors or sa buong makina in the long used, thanks po mga Sir.
    Sep 2006
    IMO walang epekto yan as long as yung Castrol engine oil is either multigrade, semi or full synthetic with a viscosity of 5W-30 or 10W-30.
    Feb 2011
    Quote Originally Posted by duramax_994 View Post
    Thanks Sir for the reply. is a castrol diesel oil but not sure for the viscosity, what if not 5W-30 or 10W-30, is there any bad effect?
    Feb 2011
    Quote Originally Posted by JhunTrooper View Post
    To be exact sir, Castrol GTX Diesel 15w-40 Exceeds API CH-4, yan yung engine oil na dinagdag.
    sir kung half liter or less lang nadagdag no problem naman po....be sure next time just use the besco oil im also not a fan of isuzu econo oil for trooper i used it once dipa umabot ng 5000km nagbawas ng langis trooper ko(dun sa mark sa dipstick ay naghalf nalang siya) but sa besco never nagbabawas ng langis...
    pag wrong grade of oil ang nagamit possible masira ORPS(oil rail pressure sensor) and/or injectors...
    if you want sir buy kanalang ng besco oil and filter sa jayson sa oil 600 pesos ang diffference pag sa casa and sa filter naman nasa 950 lang sa jayson dalawa na yon sa casa isa 900pesos and the small one is around 500pesos
    Feb 2011
    Quote Originally Posted by dh0n View Post
    Salamat sir dh0n sa reply and good idea and savings as well kung sa jayson ko nalang bibilhin ang oil and filter, maybe sa susunod na uwi ko dun ko nalang bibilhin yun, btw, saan shop mo pinapa labor or DIY mo lang ba? thanks ulit.
Trooper 4JX1 engine, dinagdagan ng castrol oil, what will happen?
