Results 651 to 660 of 1445
- Jun 2004
- 290
November 5th, 2010 12:22 PM #652
i hope i can explain it well.
yung egr flange connected sa intake manifold e tangalin mo. tapos gawa ka ng plate almost the same size nung flange. place it in between the flange and the intake manifold. parang you are blocking the air in the intake manifold to go out dun sa flange. hth
November 5th, 2010 10:26 PM #653
Eto yung sinasabi ni niwde
goto this site to see the actual picture kung papaano gawin http://www.itocuk.co.uk/forums/viewt...t=egr+blanking
- Sep 2010
- 47
November 8th, 2010 10:08 AM #654Mga Trooper Gurus,
Pwede ko po ba malaman kung normal lang na my vibration yung kambyo khit A/T yung trooper ko. BTW 2003 skyroof edition yung akin. Para kasi nung binili ko yun eh wala naman ako napapansin na vibration, 2nd owner po ako.
San po maganda ang service para sa change oil?
Yung record kasi ng trooper ko sa Isuzu balintawak OK po b na dun ko na rin ipagawa.
Maraming salamat po.
PPX
November 8th, 2010 11:12 AM #655
- Sep 2010
- 47
November 8th, 2010 12:13 PM #656Thank you Sir Benzmizer,
Im from Malabon pero mas madalas ako sa Manila area.
Magkano po ba normally ang change oil sa CASA, matagl po ba ito gawin? Bukod po sa change oil, ano papo ba ang kailangan ko para sa maintenance ng Trooper ko? Salamat po ulit ng marami
PPX
- Apr 2008
- 6,237
November 8th, 2010 02:13 PM #657Bukod sa motor oil, change the filters regularly, and have the filter cleaned every now and then ( I'm pertaining to the big red one at the lower right side of the engine compartment that's covered by a a big rubbery black cover, what's it called again? It suddenly slipped my mind. ), and have your injectors been changed already? Also, check if the differential oil has been changed already. Last time we noticed that the rear end of the car seemed to be coming loose when accelerating from standstill. Turned out that the differential oil has never been changed before in its eight years of existence.
- Aug 2009
- 420
November 8th, 2010 02:58 PM #6582002 Isuzu Trooper Skyroof Edition
1) Can we use rancho shock ? rancho rs5000 or rancho xl9000
2) Can we use MOBIL 1 GOLD Fully synthetic oil 5w-40?
- Apr 2008
- 6,237
November 8th, 2010 03:21 PM #659Besco 5W30 or 10W30 only, bro. We all know how finicky the 4jX1 is.
- Sep 2010
- 47
November 8th, 2010 03:28 PM #660Salamat po Sir GTi,
Pano ko po malalaman kung napalitan na yung injectors ko? kung hindi pa po ano po ang dapat kong gawin, libre po ba ang palit nito kung skaling hindi pa yun napalitan at CASA maintained naman.
Yung differential oil po ba e kasama din s PMS or as neede lang.
Salamat po ulit.
Kwento ng katrabaho ko, meron daw sya officemate dati na Italiano na tinanong daw bakit...
Traffic!
