Results 641 to 650 of 1445
October 22nd, 2010 09:16 PM #641
- Jun 2004
- 290
October 25th, 2010 10:18 PM #642hi mga peeps.
does anyone have a pdf of the service manual of the trooper with 4jg2 engine? thanks.
mintoy
November 1st, 2010 11:54 PM #643
4jgtootsie, kahit yung sa jdm na 4jg2 okay lang din. me paggagamitan lang ako sasakyan as long as it is aluminum.
mintoy, seach mo lang. meron ako kaso medyo malaking file. di ko lang makita yung link kasi naformat yung hardisk ko. dun sa sa parang source ng mga automotive file. bauschan ba yun? kasama nya pati mga susuki, toyota, rover pdf files. hth
November 1st, 2010 11:58 PM #644
benzmizer; baka me alam yung contact mo how much yung fender flare(complete) ng trooper. paki PM naman bro. tia
- Jun 2004
- 290
November 2nd, 2010 10:19 AM #645
- Jun 2004
- 290
November 2nd, 2010 10:30 AM #646hi mga peeps,
question on the egr of the 4jg2. when i got our trooper lotus, i noticed the the egr vacum tubes were not connected. when i connected them. we noticed black smoke while running. i disconnected the vacum hoses again and no black smoke comes out.
my question is what is the purpose of the egr and will it be ok to disconnect it permanently? thanks.
- Feb 2003
- 1,038
November 2nd, 2010 10:53 AM #647EGR is known as exhaust gas recirculation. It is an emmission control device thats fitted now to most cars diesel/gas engines. It's purpose is to reduce the NOX formation on your exhaust by lowering the combustion temp. Though it recirculates 5-10% of the inert exhaust which we perceived as a very hot gas, it actually lowers the combustion temp due to displacement of excess Oxygen in combustion chamber. Technically and by most experience having it disconnected doesn't have a big impact sa engine performance. Yung nga lang tyak mataas ang NOX emmission mo.
Drawback ng meron nyan is the formation of carbon deposits sa intake manifold and intake valves, in the end nakasave ka nga ng NOX emmission pero ang particulates emmission mo naman is tataas kase due to inefficient combustion..kaya umuusok ang kapag kinabit mo ang vacuum hose. Now kung newly cleaned ang intake manifold and egr valve, dapat hindi sya mag emit ng black smoke. Constant cleaning maintenance dapat kung gusto mo na nagfunction ang egr.
November 2nd, 2010 10:55 AM #648
yep its the same manual as mine. di ko kasi sure kung me timing belt diagram yung sa manual ko. pero i thinks its the same as mine.
re; egr, if i were you block mo na lang yung egr. minsan kasi na stock sya open kaya lagi circulate ang exhaust gas sa intake. para lang sa emission control yan. yung local na 4jg2 afaik wala.Last edited by niwde11; November 2nd, 2010 at 10:58 AM.
- Jun 2004
- 290
November 2nd, 2010 07:31 PM #649thanks guys for your reply's on the egr. i guess i'll keep it disconnected cuz during an emission test. its the particulates that they measure. will just keep my hho gen on to hopefully reduce the nox.
November 2nd, 2010 11:20 PM #650
block off mo na ng blank plate. kasi problema nyan baka mastock open yung valve.
Monk-owned R53
