Results 1,131 to 1,140 of 1445
- Aug 2009
- 420
January 6th, 2013 07:15 PM #1131sir. where can i buy original atf filter and atf for isuzu trooper 4jx1 engne other than CASA. banawe area? shop name? thank you
- - - Updated - - -
- Aug 2009
- 420
January 11th, 2013 09:08 PM #1132sir s_quilicot, after using the Royale purple, ok namang ung transmission performance sa trooper mo? i think nasa 895 per liter na yung royale purple atf right now. sir with transtech dialysis machine, hindi kayo nag change atf filter? i ask a EXALTA mechanic, they needed 15 liters atf for the dialysis. axe and differental for what po yan? (",)
any recommendaton atf for trooper other than sa CASA? dexron II and III,
- Sep 2008
- 587
January 17th, 2013 02:35 PM #1133Can anyone help me out. I need a rear reinforcement bracket for my Trooper 1997 3.1 TD, full of rust na kasi and nahirapan ang latero to fabricate. Kung wala, can anyone help me out to source kahit rear bumper assembly na lang, nandito kasi ako sa province and ang hirap humanap suppliers, thanks
- Sep 2010
- 47
January 23rd, 2013 06:43 AM #1134Trooper gurus,
Malakas po vibration ng trooper ko (skyroof edition). Ng pa change oil ako tapos ang sbi skin patay n daw injectors ko (1&2). Meron po b mkukuhanan ng injector other than casa. Ok lng b kung surplus lng pkbit ko.salamat po sa mga mag rereply.
POPPIX
- Nov 2010
- 236
January 23rd, 2013 07:12 PM #1135
- Sep 2010
- 47
January 24th, 2013 09:12 AM #1136
- Sep 2010
- 47
January 24th, 2013 09:15 AM #1137
- Oct 2012
- 13
January 26th, 2013 12:37 PM #1138Sir Poppix just a quick and maybe helpful advice for you regarding the vibration.....Have you had your motor mounts checked? I just had my Pajero running smooth again by having the engine supports (motor mounts) replaced. 20 years old and so worn out. Go for the original ones as they are softer than the aftermarkets. Though pricy they surely will last for another 10 years. It may also work on your Trooper. With my Trooper, I had a freak occurrence of vibration before which lasted for a few seconds during an idle. I thought it was a sign of failing injectors but I assumed it was water in the fuel as it never happened again. Hope this helps.
- Sep 2005
- 224
January 27th, 2013 12:28 PM #1139
January 27th, 2013 05:03 PM #1140
Sir if papalitan ang injectors mo, I suggest a total quotation from your casa or your trusted mechanic. Baka mamaya mala new year ang surprise mo sa laki ng Bill.
I was at Bosch Center in dagat-dagatan back in November, I asked one of the technicians there kung anu opinion nila sa saket ng 4JX1 injector problems. sbi nila Yes It can be repaired, but some of the parts used to repair it are surplus for reasons that Isuzu does not manufacture them anymore (4JX1 discontinued d b?). I've seen a couple of Troopers there under going repair similar to your problem
F.Y.I. some casa's when they can't solve problems regarding trooper injectors they send it to Bosch. I don't see any reason why they would say otherwise to me since I don't have a trooper and I believe they are just being factual. So why dont you ask Bosch either in quezon ave. or in Dagat-dagatan.. or you can ask Diesel dude under http://tsikot.com/forums/engine-fuel.../index194.htmlLast edited by blue_gambit; January 27th, 2013 at 05:08 PM.
Monk-owned R53
