Results 81 to 90 of 126
- Apr 2012
- 94
October 18th, 2014 10:47 PM #81Salamat naa jud taga davao.
Xwind 2004.
Limpyo tangke
Limpyo sedimentor
New fuel filter
Normal menor
Pero:
1. Kurog engine during ac on (inig pitik sa compressor on) pero inig off na pd sa compressor (ac on gihapon)mawala man kurog.
2. White smoke sa dipstick.
Unsay findings nyo mga bradi?
Salamat daan..
- Aug 2014
- 391
October 20th, 2014 03:20 PM #82white smoke sa dipstick, (mag tagalog lang ko basi naa masaag taga menila)
meron na din xtrm ko nyan, sabi nung ibang mekaniko, baka meron na palya head gasket, or piston rings, pero probably head gasket then bruning a little water from the radiator na dumadaan sa cooling system ng engine.
Sabi din ng iba, baka not good or madumi na yung CCV (Closed Carnkcase ventilation ) yung breather na supposed to exhale the blowby but if marumi na, so konti na lang blowby dadaan.. then as long as ok pa namn takbo ng sasakyan, wag mo daw muna pagalaw.
try to measure voltage if engine is not running - usually, 12.5, if running (alternator is running) then 13 or 14, AC on. if below or still 12.5, then something is wrong with your alternator.
- Apr 2012
- 94
October 20th, 2014 10:43 PM #83Salamat sa inputs.so far ok ra man jud yang hatak.kusgan man gihapon.napa adjust na pd nko idling ac on.arang2 na.walay kurog.kurog lng kng cold start.pero kng init na,ok na tanan.so dili na lng nko pahilabtan ang makina regarding sa smoke?
- Aug 2014
- 391
October 20th, 2014 11:49 PM #84matud sa mga naka istorya nako nga mekaniko,, unahon sa ang basics.
valve clearance - adjust
oil basi kinahanlan na change
breather - basi barado na
check ang tubig basi mahutdan ba.
pwede nimo pa tanaw makina kung dili issue ang budget.. ug unless wala na gyud daw kusog. share nya sa imo next move.
- Apr 2014
- 132
- Aug 2014
- 391
October 21st, 2014 07:59 PM #86
- Apr 2014
- 132
October 21st, 2014 08:46 PM #87
- Aug 2014
- 391
October 21st, 2014 09:40 PM #88OCC, pwede, pero kung ako, makalugar ko, ako na lang e-bend 90 degree and hose, then bend again 90 degree, going back to intake.. para ang oil, dili kasaka, mubalik ra.. naa ko nakita sa uban, bend 90 degree, to open air.. pero naay gagmay nga air filter nakakabit sa tumoy.
thermostat, ala pa.. ngano diay imong tangalon?
- Apr 2012
- 94
October 21st, 2014 11:27 PM #89Salamat sa inputs.napa adjust up gamay ang ac idling nko.naulian man pd.wala na kurog.kng cold start lng,then taod2 ok na.ang aso na lng jud.ana pd tung taga shell ecoland,breather daw palimyohan.swito lgi kau ka sir aoishin?naa kay shop?bcg pwede ko pacheck nimo?
- Aug 2014
- 391
October 22nd, 2014 07:30 AM #90wala koy shop oikim, pero xtrm nako naga aso sab sa dipstick.. ikaw na lang DIY ana, ako man gud, gina hilabtan nako ibabaw sa makina, then makita nimo ingon ana diay, limpyo lang sa breather, tangalon lang ang hose, kanang sa image. isa lang ka bolt ug mga panghugot sa hose, then tanawon nimo kung lusot pa ba hangin, BUT, that will not solve the smoke from the dipstick, Im sure something is being burned inside that cause the smoke, either water or oil, which probably caused by worn. gaskets. Ang ako, wala pa nako pahilabtan, mudagan pa man, nya dili man kayo aso ang tambutso.
I went with him at LTO's The Link satellite office nung nag-renew sya. We were given a number to...
