Ask kulang po! Bakit yung isang tire (left side-back) madaling ma podpod (numipis) aside sa tatlong natitirang gulong almost new pa?![]()
pano matangal ang langitngit sa under chassis ng Crosswind XUV? nakakairita ang ingay nya. TIA
Good evening po sa lahat...am a newbie here. Glad to have found this forum which is a very rich source of info. Indeed, i have learned a lot just from reading the so-many posts in here...for the benefit of my Sportivo '05.
Rightnow, I am interested in installing a helper leaf spring such as the LoadPlus, inasmuch as I usually carry a heavy load.
Any comment/info from you guys regarding this? Would anyone know a shop in Nueva Ecija who can install such? TIA.
Do you have any idea how much loadplus is?
Saw this video.
http://www.youtube.com/watch?v=zMzhvIwIRyE
It will be better if you can read the basic informations for the car suspension in order to be cleared for you.
http://auto.howstuffworks.com/car-suspension1.htm
Thanks Tholitz for the video link. Ganun pala LoadPlus...it seems to provide help to the leaf springs whether you need it or not i.e. whether you are loaded or not. Well, according to Sir Benz, it costs P4-5k and Winterpine at Araneta Ave. is a distributor.
I have seen another version of a helper spring - one that is installed under the existing leaves - designed to provide help only if necessary ie when loaded. That is, wala siya effect under a normal ride. I just dont know kung meron na nito sa 'Pinas. It is called Maxloader.
[QUOTE=noelbranz;1558377]I have a problem with my Isuzu Crosswind XT 2007.
When I am stuck in a steep slope (like SM Megamall parking) --- the first gear has very low power -- almost cannot move and the engine stop.
Ano kaya problem nito?
Thanks
-I am new here...
"baka kulang ka rev.. sir"
Hello mga Sirs,
Thanks nga po pala nakapagtanong na ako sa Jason Auto Supply. Mura nga sa kanila ang parts!!!! :-)
Additional question lang po, kasi ilang days pa lang nasa akin ang 2003 crosswind xuvi.
1. Yun po bang Pioneer na player ay CD lang ang pwede?
2. If CD lang po then ano ang use nung 2 lcd sa headrest?
Pasensya na mga sirs, wala kasi manual kasama nung mabili ko.
Thanks again.
*LASTPOGI: Re Load Plus, I guess its a natural consequence na magiging stiffer ang ride. Eh kasi, it is perpetually connected to the leaves - making them stronger at all times.
In contrast, if the helper spring is installed sa ilalim ng leaves - under the shortest leaf (as with the Maxloader), may space between the longest and the helper leaf. No touch sila when there is no heavy load kaya no change with your ride is felt. Kapag heavy load at sag na si vehicle, dun palang sila contact at tutulong na si helper leaf.
Sirs, ask ko lang po kung ano tawag sa small part ng side mirror na nasa picture pionted by arrow? And kung saan makakabili nun? TIA
