Results 1 to 10 of 23
- Apr 2009
- 536
November 28th, 2011 07:09 PM #1Hi Fellow Crosswind owners. Gusto ko na pa change ng Transmission oil and Gear oil sa Gas Station.
I just need an idea how much magagastos ko sa oils. Dati brother ko nagpachange kaya hindi ko alam ang memorize
ko lang yung sa Engine oil kasi more frequent ang change oil
How many liters sa Transmission oil? Gear oil?
thank you
- Sep 2010
- 181
November 28th, 2011 11:54 PM #2kapapalit ko lang nung sa akin,sa transmission ay 1.9 liters engine oil...sa differential ay 1.5 liters gear oil...inabot ng almost 2K kasama yung sa engine oil saka mga filters...so,di pa siguro abutin ng 700 yung sa differential at transmission...
- Apr 2009
- 536
November 29th, 2011 10:40 AM #3Thank you. kaunti lang pala, Transmission oil is the same oil used for engine oil. I will bring it
sa Petron this weekend sabay ko na pa greasing.
- Sep 2010
- 181
November 30th, 2011 03:13 AM #4ok bro...nahihirapan lang sila maglagay ng engine oil sa transmission...hehe...sabi ko kasi,talagang di pwede ang gear oil sa transmission ng crosswind...kaya gumagawa nalang sila ng improvised na funnel...
- Apr 2009
- 536
December 1st, 2011 12:14 PM #5I brought it na sa petron. tama nga almost 2 lit sa transmission and 1.5 lit sa gear oil plus greasing gastos ko
695 pesos only.
yung sa gear oil ginamit niya yung 90 meron na sila nasa container. sa Transmission naman sabi yun din daw
I insisted na dapat same as Engine oil so I got 2 liters of Trekker 15w40. Sabi ng mechanic ng petron
yung iba gear oil din ang gamit sa transmission. I asked yung trusted mechanic ko sabi niya ang gamit sa transmission
same din sa gear oil. pero d ba sa manual should be engine and transmission oil are the same?
ano ba tama? makakasira ba sa transmission kung gear oil ang gamit?
- Sep 2010
- 181
December 1st, 2011 03:00 PM #6Isuzu lang kasi ang may ganyang system na same oil ang gamit sa engine and transmission....kaya wag kang papayag na magpalagay ng gear oil sa transmission bro...ako,until now,smooth na smooth pa din yung shifting ng sasakyan ko,kasi talagang engine oil ginagamit ko,yung ibang crosswind,kaya siguro di tumatagal yung tranny nila,kasi nagpapalagay ng gear oil instead of engine oil...
- Apr 2009
- 536
December 1st, 2011 05:02 PM #7Ok naisip ko lang paano yung mga walang manual. malamang gear oil din ang nasa tranny.
thank you
- Nov 2011
- 171
December 6th, 2011 10:40 AM #9*** gear oil ang nilagay ng mechanic ng petron kahapon sa transmission ng xmax sportivo ko.
Engine oil lng sana yung papalitan ko kc 4.5k n ang sa odo k0 and its almost 6m0nths na di na change oil yung engine ko.back tayo sa topic
ngayon ko lng nabasa to eh.
ok lng ba yun mga parekoy?
or dapat palitan yun ng engine oil.
ayaw ko lng agad masira xwind ko.
anyways gumanda nman shifting ko ng gears pgkatapos nalagyan ng gear oil ang transmission,ano lng ba ang dapat lagyan ng gear oil sa xwind?
Try to read the manual again bout the pms,nagmamadali kasi ako kahapon.
- Nov 2011
- 171
December 6th, 2011 10:47 AM #10*** gear oil ang nilagay ng mechanic ng petron kahapon sa transmission ng xmax sportivo ko.
