Results 151 to 160 of 224
- Nov 2011
- 6
December 1st, 2011 11:55 AM #151
- Nov 2011
- 6
December 1st, 2011 11:57 AM #152
- Nov 2011
- 6
December 1st, 2011 01:47 PM #153Mga Sir follow-up question po. Sa fan belts po natin, alin po mas maganda gamitin, yung may ngipin na belt or walang ngipin? and wat brand po?.. Pa cenxa na po sa term, di ko kasi alam anong technical name talaga ng belt..
December 1st, 2011 02:02 PM #154
- Apr 2012
- 6
April 4th, 2012 08:14 AM #155I have a 95 Ls Pickup with 4JA1 engine, no problem so far. tried to ask a couple of mechanics to overhaul, ayaw buksan. except for the usual usok. Normal lang daw yung white na usok. hehehe. Problem nga yung mga nang huhuli ng smoke belching. Btw, does anyone know kung ubra mga kabit ng turbo sa stock 4ja1? Anu con's and pro's on having it? How much does it cost?
- Apr 2012
- 6
April 4th, 2012 08:35 AM #156wala po ba website yung supplier fr australia? interested to check their sites.
April 4th, 2012 10:50 AM #157
Just buy a surplus Crosswind turbo. With the low boost (mga 6 psi), it won't require much adjustment to the fuel pump to make it run... just bolt it on and you're done!
You can go one better by using a 4JB1 turbo, but that might require more fabrication and you definitely want to adjust the fuel pump calibration to match the turbine.
- Apr 2012
- 2
April 8th, 2012 04:02 PM #158sir kmzta po..ask ko lng po kc yung fuego na 2004 model ko..ngoverheat sya kapg ntrafic at nkapark..ngbabago din yung menor ng engine at nawawala lamig ng aricon..pingawa ko na radiator,injection pump,pti chnage oil tuneup na ko ganun pa din?salamat
- Jan 2011
- 108
June 17th, 2012 09:51 PM #159sir, pwede po ba magtanong? ano na po ba ang options na pwedeng gawin kapag sobrang nginig na nung engine ng crosswind? 2004 xuvi tsaka white na po yung usok niya. help po pls.
- Jan 2011
- 108
June 17th, 2012 09:52 PM #160Kailangan na po ba ng calibration dito? o linis yung mga nozzles and injectors? 51k mileage palang po siya
Somewhat expected from a rushed car from a first time carmaker
Xiaomi E-Car
