Results 101 to 110 of 224
- Mar 2009
- 125
April 14th, 2011 06:52 PM #101
- Mar 2009
- 125
April 14th, 2011 06:55 PM #102
- Feb 2011
- 25
April 15th, 2011 07:16 AM #103
April 16th, 2011 12:51 PM #104
Mga Sir's paano po ba malalaman if na break-in na po ba ang isang engine? TIA po
April 16th, 2011 01:22 PM #106
April 16th, 2011 02:43 PM #107
Hello mga sir ask ko lang may naririnig kasi akong noise coming from transmission parang nag huhumming sya kapag naka shift na sya from 1st gear to 5th gear and reverse pag naka neutral wala naman ako naririnig na humming. naririnig ko lang yung humming sound kapag umaarangkada na kapag binitawan ko naman yung accelerator pedal nawawala yung humming sound atsaka ang hirap ipasok ng kambyo parang may sabit tapos yung clutch ko parang ang tigas.
- Mar 2011
- 28
April 18th, 2011 06:06 PM #108
April 18th, 2011 06:19 PM #109
This might help you.
White smoke is normally ‘steam’ which means water is vapourising! If it is white ‘smoke’ then it could be as a result of low engine temperature. White Smoke will smell of unburned diesel - White ‘Steam’ will not!.
AFAIK, puwede lagyan yung old school diesel ng 2T sa fuel tank para makatulong sa decarbonizing. 128:1 ang ratio para safe. Done it already. No problems so far. Still checking the FC if it will improve but i doubt it. Decarbonize lang talaga.
http://www.dieselsmoke.com.au/Last edited by Ry_Tower; April 18th, 2011 at 06:33 PM.
- Mar 2011
- 28
April 21st, 2011 11:02 PM #110sir 128 ml of 2t is to 1 liter of diesel? ganun po ba ang ratio? sorry newbie
see my pahabol statement above. i mean, i can go on vacation anytime. but my spouse has her...
Traffic!
