Results 171 to 180 of 224
October 12th, 2014 11:59 PM #171
from my experience and some research on the net, may dalawang transmission models fitted sa mga 4JA1. eto ay yung MUA & MSG. the MUA trans have higher gear ratios so much better ito on uphill climbs, load carrying, etc. yung company service ko non e MSG. hirap na hirap umakyat pero nakaka 140 kmh sa hiway. MUA trans oil capacity is about 3 liters while yung MSG e approx 2 liters naman. nalaman ko ito nung drinive ko yung isuzu pickup ng kaibigan ko. ramdam na ramdam ko yung difference sa uphill climb and load carrying sa 1st gear pa lamang. mas relax ang makina sa MUA trans.
from my observation, may selected models ng LS (pre fuego models) at siguro may konting fuego models na naka-MUA transmission. at lahat ng IPV e naka-MUA trans din. ang quick way para malaman is the length of the shift lever at yung location nya on the transmission tunnel sa body. mas malapit sa engine yung shift lever ng MUA kesa sa MSG trans.
i'm planning na rin na iswap ang aking lumang mitsu pickup sa isuzu pickup e. nakakasawa na rin isipin parati yung kondisyon ng timing belt ko.
- Aug 2014
- 391
October 18th, 2014 09:28 AM #172Seems there was a little air inside the water separator, just bleed it and its ok after that, I remember i cleaned and replaced fuel filter, maybe i was not able to do proper bleeding that time.
- Apr 2014
- 132
October 21st, 2014 07:45 PM #173Guys my ride is a xwind 2004 model tinanggal ng radiator specialist ang thermostat kasi no need na daw dito sa pilipinas kasi hot climate tayo. Anyone done this also and any inputs sa performance and FC. Thanks sa mga makapag reply..
- Apr 2013
- 236
October 22nd, 2014 04:02 AM #174Marami na gumagawa niyan pero nagsisi sa bandang huli. Bakit naman tatanggalin yan eh important component ng engine cooling system yan. Kapag walang thermostat, mas matagal ang cold start mo. Malakas sa gas. Hindi din ma aachieve ng engine ang optimum temperature niya sa highway driving. Magiging sluggish ang engine. Kung no need na dito sa atin sa Pinas yan, dapat sa factory pa lang tinanggal na yan. Nakatipid pa sana lahat ng auto manufacturer. Nilagay yan kasi may purpose yan. Siguro ang mas maganda tanggalin mo, yung mekaniko mo. Hehe. Ipabalik mo na lang ulit yan thermostat.
Posted via Tsikot Mobile App
- Apr 2014
- 132
October 22nd, 2014 09:03 PM #175
- Oct 2014
- 5
October 25th, 2014 07:13 PM #176
- Oct 2014
- 5
October 25th, 2014 07:20 PM #177Same with mine sir. Year 1992 pa pero same engine lang non-turbo 4JA1 and yes hirap na ako umangat pa above 100kph sir be it a straight highway without kasalubong or kasunuran. Done that with the 5th gear at kahit anong sagad ko sa accelerator pedal halos hirap ng humugot pa ng speed yung makina, kita ko naman sa speedometer at RPM gauge hindi na halos tumataas. Staying between let's say 1800-2000 rpm. Di talaga siya ganon kabilis because I've driven the same road (same condition) using our non-CRDi TDi 4D56 strada at kayang kaya ko pang umabot ng around 140-150 kph eh.
- Oct 2014
- 5
October 25th, 2014 07:27 PM #178Sir, hindi ko lang 100% sure kung totoo ito ah pero palaging sinasabi sa akin ng father ko na mas mabuti na daw kung medyo mausok yung sasakyan mo basta kulay itim yung usok na lumalabas kaysa kulay puti. Try mo ask sa iba sir. Mine is medyo mausok din pero itim at may nginig din minsan (although this could be broken engine support lang or maduming fuel pump e.g. may tubig sa loob or maduming air filter; my car used to be shakey din noon but then nung pina-service ng father ko paguwi niya wala nang alog, sabi niya nilinis ng mechanic yung air filter kasi madumi na halos may lumot na and yung fuel pump because madumi na! sometimes ngayon medyo umaalog siya and maybe baka kelangan ko ng palitan fuel pump and air filter but it's just that na inayos sa akin wala na alog)...
- Oct 2014
- 5
October 25th, 2014 07:39 PM #179Base on my experience~
a. Battery Indicator - Yung sinasabi na I.C. sa alternator. I think it's the most sensitive part of the alternator eh and I don't know sa ibang place ha but dito sa amin yung mga nagbebenta ng ganyang parts ay may "No Return Policy". It's either you get a good I.C. or a defective one. I don't know bakit ganon. I had mine changed few months ago, mabuti it was a good buy pero same lang tayo every startup ko especially sa umaga (first start-up) always nag-aappear yung battery indicator pero nawawala when I rev up the engine. But be reminded na if hindi pa din nawala kahit anong rev up mo, alternator na may problema, hindi na siya nagchacharge. Or baka grounded connection ng indicator pwede rin so it keeps on showing up.
b. Oil Indicator - base on my experience, nag-aappear yung ganon sa akin na matagal and kelangan pa i-rev up (just like that battery indicator problem) nung time na hindi ko namalayan yung engine oil ko konting konti na lang pala (those times na may leak sa oil seal ng engine ko and transmission so unti-unting nauubos yung engine oil). I also took notice during those times na konting konti nalang engine oil ko, pag mabilis takbo ko and then magmemenor ako to turn to a road in my side (whether left or right) nag-aappear for a split second yung oil indicator but then kahit na konti nalang engine oil ko nung time na yun, hindi man lang nag-overheat yung engine or uminit na katumbas ng init ng ibang engine during normal usage good condition. Iba talaga 4JA1, di ko alam bakit hindi masyadong umiinit :/
- Aug 2014
- 391
October 28th, 2014 06:16 PM #180Oil indicator, I remember, yung oil indicator signal ay galing dun sa oil sender sensor, baka naman loosen na yung nakakabit na wire kaya pag inalog, nag loloose contact kaya nag sesend ng signal. Patingin na din baka meron ng leak dun sa portion na yun.
Did some independent research and decided to go with the white pearl crystal.... para maiba naman. ...
