Results 11 to 17 of 17
- May 2012
- 67
October 22nd, 2012 01:35 PM #11Negative pa Sir parakito. Di pa rin napapalitan ng casa. The worst part is that the problem came back again last week. That time, it lasted for about 20 minutes. Natatakot nga yung kaibigan ko that time, kasi it might cause an accident. So, she brought the unit again at the Hyundai Shaw. Luckily that time, their chief technician was there and at that time, they were able to personally witness the problem. It was the first time that they actually tested the unit where the problem was actually experienced by them.
The unit was asked to be left for 2 nights. They just had the sensor re-set. They still have not replace the Oil Temp Sensor. According to them, they will have the part ready within the week. Will provide update soon.
- May 2012
- 67
October 22nd, 2012 01:37 PM #12
- May 2010
- 13
October 29th, 2012 03:57 PM #13I think the transmission issue w/ SF is not an isolated case. Been following different forums the the all report same issues with the transmission. Even the Sorrento suffers the same issue.
But after the replacement of the transmission solenoid everything is ok. Nothing to complain about
- May 2012
- 67
October 30th, 2012 10:42 PM #14The oil temp sensor was the part that got replaced. According to my friend, the problem is almost gone, except for a slight nudge she feels sometimes when the gear shifts. If the problem persists, i will ask them to check the transmisson solenoid.
On a related topic, i hope this is not related to a problem mentioned in one of the threads on this site regarding connivance of some casa people in swapping of good parts from cars undergoing PMS to some unscrupolous individuals. The problem started after her 10k kms PMS.
- Mar 2011
- 99
November 8th, 2012 01:52 PM #15Even if you insisted na dapat nang palitan yung xmission solenoid I don't think they would..why after the 10k PMS sa shop nila it happened? obviously dapat palitan talaga yan..or hintay na lang uli until the error code pertaining to that issue shows up I guess.
Rampant sa 'pinas yang mga estilo na yan..syempre this is one way of subsidizing their low income..eh di mag generate ng income sa mga binabaklas na pyesa..it's not so far fetched kaya naniniwala ako sa haka haka nyo about parts swapping sa mga casa. Ako nga nahuli ko mekaniko na yung oil filter na binili ko ay di nya ikinabit dun sa motor ko for an oil change..nakalubog na kunyari yung lumang filter sa oil. After I got home pag check ko hindi naman yung filter ko ang nakakabit! Granted it was only a sub 200 peso part but they somehow earn extra bucks doing things this way..imagine kung magkano ang xmission solenoid sa casa...hmm
- May 2012
- 67
December 7th, 2012 06:38 PM #16Update lang mga sir. The Oil Temp Sensor was replaced in October. Eversince, it's now Ok. Problem never came back. Thanks mga brods.
Only those not owning an EV have range anxiety.
Hybrids and EV
