Results 41 to 50 of 53
September 30th, 2014 05:41 AM #41
Except sa pinalitan na lahat shocks, very satisfied sa 2013 accent ko. Lakas aircon at swabe pa rin.
Di rin ako mapili sa gas. Fuel save phoenix caltex silver. Wala naman kumakatok at malakas makina.
Why not brand new? Mura na mga dp ngayon.
Posted via Tsikot Mobile App
- Oct 2008
- 3
September 30th, 2014 06:42 PM #43mahirap po kasi makakita ng 2nd hand vios na low mileage, sa accent medyo madami.
- Jun 2008
- 1,741
October 1st, 2014 10:53 AM #44
ang alam ko yung ilan ilan sa first batch ng 1.4L accent nag karoon ng knocking issue. yung next batches ok naman bsta 95 RON ang gasolina gamit kasi high compression ratio ang makina. Yung manual tranny tulad sa brother ko wala naman knocking kahit normal unleaded gasoline ang karga. hiniram ko yun for a week at pinakiramdamdaman maige pero wala talaga engine knock.
- Jul 2014
- 162
October 12th, 2014 01:32 AM #46
11800 kms. na sa odo ko and still got no issues with knocking or mechanical failures. Tried cruising 140-160 kms. on SCTEX and TPLEX to test if there will be any problem, so far still running good. Still using unleaded gasoline, I hope solve na nga knocking issues with new kappa engine.
- Aug 2015
- 25
August 16th, 2015 01:37 PM #47Mu hyundai accent reached a 57k km run, 2011 model sya manual 1.4 engine, last thursday pag kauwi ko galing ofis may napansin ako bigla na maingay sa engine ko na parang may roleta ang ingay. So inisip ko na due na rin sya sa pms ko. So nung friday nag pa pms ako hoping na mawawala na sya kc i checheck nman nila lahat. Pag ka pull out ng kotse ganun pa rin ang problema, ang sabi nila mag automatik adjust kc ang valve nya pag ganun pa rin next week ibalik nyo sa amin. As of now ganun pa rin sya try ko isingit sa schedule ko for the next 3 days kc may pasok rin ako.
- Aug 2015
- 25
August 16th, 2015 01:43 PM #48My hyundai accent reached a 57k km run, 2011 model sya manual 1.4 engine, last thursday pag kauwi ko galing ofis may napansin ako bigla na maingay sa engine ko na parang may roleta ang ingay. So inisip ko na due na rin sya sa pms ko. So nung friday nag pa pms ako hoping na mawawala na sya kc i checheck nman nila lahat. Pag ka pull out ng kotse ganun pa rin ang problema, ang sabi nila mag automatik adjust kc ang valve nya pag ganun pa rin next week ibalik nyo sa amin. As of now ganun pa rin sya try ko isingit sa schedule ko for the next 3 days kc may pasok rin ako.
August 16th, 2015 04:33 PM #49
Check your compression ratio. Most Hyundais are high compression and requires high octane fuel
August 16th, 2015 05:20 PM #50
During startup lng? See the video here:
Very loud clicking (knocking?) on Cold(ish) Start - Hyundai Forums : Hyundai Forum
just seen a 10th gen cross 200,000 miles on reddit. is this a unicorn or has the cvt been proven...
All New 2016 Civic
