Results 41 to 50 of 1692
April 20th, 2010 08:56 PM #41
sir mackie, linis ng ilalim ng oto nyo ha hehehe
so how will the rear cam be adjusted?
April 20th, 2010 11:00 PM #42
nako wala nga
hirap pa naman kung palaging naka bukaka yung gulong sa likod, hindi pantay ang kain ng goma. Hindi naman Nitto Neo Gen yung stock tires natin.
- 635
April 21st, 2010 12:13 AM #43
April 21st, 2010 12:25 AM #44
alam ko etong bolt na to ang ini-ikot para maadjust camber...correct me if i'm wrong.
April 21st, 2010 12:32 AM #45
try mo sir yung sa Tucson mo tapos balitaan mo kami.
pero ang alam ko yung nasa ibabaw nyan ang para sa camber.
- Jun 2008
- 1,741
April 21st, 2010 12:59 AM #46
- 635
April 21st, 2010 10:23 PM #47
April 27th, 2010 11:59 PM #48
i just had my tuc lifted earlier and checked the encircled bolt. there are gauge marks along the bolt indicating the degree of movement. this could very well be the bolt to adjust camber. on the other side of the suspension arm, i also saw a bolt which adjusts toe. apparently, the hyundai technician agreed that it does adjust camber.
negative camber is fine with me, it keeps the car more stable and increases side bite on curves. for 2wd cars, this should be fine especially if the rear wheels are only dragging... for awd cars, it results in uneven treadwear.
April 28th, 2010 12:03 AM #49
Yan ang magiging problema ko sa 4WD.
mackieboy, saang bansa pupunta si sir Jorge?
- Jan 2008
- 4,726
April 28th, 2010 12:20 AM #50
