Sir LucasVN,
Thanks ok naman battery... Nagstart na tucson... I wonder why hindi nagstart kanina... 1 year pa lang naman tucson ko para pumalya ang battery.. Anyway observe muna ako. Thanks again.
Sir LucasVN,
Bought mine june 2011, so far wala pa ko stablink, ac, transmission shift issues....
Re: Brake pads.... Sino na nagpalit sa inyo ng brake pads... Kaasar kasi kaka hugas / punas lang dumi agad ng mags hehehehe... Ano ba maganda kapalit nito and How much ba ito and san available?
Madami aftermarket brake pads sa eBay. Kaso di ako sure dun sa mga brand. Ceramic brake pads daw.
Bendix kasi talaga pinaka ok na aftermarket brake pads.
Just for an update, my Tucson that was bought in April this year still has no issues....Very happy with it so far![]()
guys may burnt smell pa rin yung tucson ix ko when going beyond 110-150kph
Any recommendations??? almost 4,000 kms na yung tinakbo ng tucson ko.
Also, off topic po..
Ilan SM ang battery capacity ng tucson?
Sir providence. Ang alam ko po ay 2SN.Originally Posted by providence
My Brake Switch finally failed after I fell into a big pothole. As in I had to insert a screwdriver into the override hole every time I had to Switch to and fro Park! Good thing Hyundai Quezon Ave had 1 more brake switch in stock and I got it replaced the next day and in less than an hour.
I got it 2nd hand. When i got it 33,+++ na sya. So far okay naman, no problems except for the brake switch and the rear stabilizer link which will be replaced sa next PMS. I manage to get around 9 km/l, which i'm pretty happy with. Hindi lang accurate yun sa dashboard meter, parang may discrepancy of 1km/ L.
nag-stall ako kanina sa commonwealth, badtrip, ganun ba tlga? while driving at 30-40kph, biglang mamamatay engine? delikado masyado, buti nalang sa UTurn slot under tandang sora bridge ako namatayan. Tinabi ko nalang, tapos ayaw na magstart, tapos after series of trying... chka siya nagstart ulit. hassle! is this under warranty? im nearing my 15k pms.
tapos sa shifting gear ko, when i pressed on the breaks, may tok tok na sound, is this normal din?
^ Fuel supply issue.
Ipa-check mo na fuel pump nyan. Mas maganda kung palitan. Sabi ko nga sa taas diba brand new unit nag-stall.
Tapos pa-reset mo ECU para mawala yung knock sound sa transmission.
Hindi ba umilaw ang check engine?
