Results 41 to 50 of 73
- Oct 2007
- 17
October 26th, 2010 12:48 PM #41Hi everyone. I have a disturbing sound with my 2004 CRDI Starex when turning while breaking. Sound like a metal to metal contact. Normally when backing or moving out from parking. I have replaced all upper suspension assembly and seamed the Brake caliper bolts. Sounds only while breaking and turning at low speed.
Can anyone would possibly know what the problem is? Appreciate your comments.
October 26th, 2010 03:41 PM #42
- Jul 2008
- 49
January 31st, 2011 07:44 AM #43my starex 04 crdi AT ang hina sa akyatan kahit ilagay ko sa L ang drive halos di maka ahon.anyone can advice what could be the cause.tks
- Nov 2010
- 66
March 25th, 2011 05:24 PM #44mga ser, patulong naman about a 2004 Starex SVX. saan kya matinong shop/talyer ng mga starex? maitim ang usok and hirap umarangkada eh, nakailang palit na ng parts in just 1 month: fuel filter, 2ndary clutch kit, clutch disk..ganun pa rin ang sakit nya. please recommend a good shop within QC area sana, ty!
- Oct 2007
- 17
March 26th, 2011 01:50 PM #45Sir try nyo palitan pati lower suspension arm ng original parts. With regards to no power I had mine clean all intake. Ang kapal ng carbon deposits sa EGR at manifold. Ang laki ng improvement in power and fuel consumption.
- Nov 2010
- 66
March 26th, 2011 11:39 PM #46
- Dec 2010
- 14
April 13th, 2011 10:11 PM #47Please help newbee palang po. Just replaced my dirty fuel filter last week, after replacement it noticed in hard restarting for almost 1 day used. For the second day in the morning I started my Starex CRDI 2005 model and won't start until now. What are the possible defects since the fuel filter had been replaced with new one? I pump the fuel filter pump just to remove the air bubbles, there's a fuel going to fuel pump. During starting, there’s a low pressure getting in to injectors. And today during push starting it will start but I wonder the engine check indicates in the dashboard, my starex before is in top condition, the 100% caused is a dirty fuel filter. Please help of what are the specific defects with my crdi engine. Your assistance is high appreciated. Thanks and more power
- Dec 2010
- 14
April 14th, 2011 09:02 PM #48Newbee po, anybody advise me Re:Starex CRDI 2005 ko. 1st owner me, 52K palang mileage starex ko. One in the morning I discover na hard starting sya, I pump the fuel pump pero hindi tumitigas, so suspect ko agad fuel filter barado, pinalitan ko agad. The old fuel filter barado nga sobrang dumi. Sa Petron Xmax lang me nagpapakarga, siguro naglose track me sa fuel filter, sobrang busy kasi last few months ago kaya forget ko na PMS starex ko, gamit lang me ng gamit. Pag tinulak start sya agad, lumakas ang hatak kc bago fuel filter, nakatakbo lang ako ng 80kph parang may malakas na umu-ogong na hangin sa makina tapos nag shut down and engine, buti nalang na control ko pa, tapos pagtulak andar naman sya uli, wonder lang me umilaw na engine check sa dashboard, tapos medyo mausok na puti at maanghang sa mata. Until now andar parin sya pag itulak, ang problem lang, pag battery starting ayaw talaga umandar, bumili na me new motolite gold battery pero ganun parin, lakas naman starter, bilis nga redondo, pero ayaw lang talaga umandar pag battery starting. thanks so much bro sa reply you.
May 15th, 2011 03:25 PM #49
hey guys, im about ready to change tires on my GRX again. 2 years ago I bought Bridgestone dueler h/t but wasnt really satisfied with the ride (better than the original kumho hi-miler, but not by much). do you have any suggestions with tire choice? I will likely keep the stock 205/70R15 size.
- Feb 2010
- 336
May 20th, 2011 12:54 AM #50you could try Michelin Agilis w/ the exact tire size of your choice, before it was Vanpix (phase-out) as mentioned in the other forum site that is best for our ride as long as it has a 100 load rating w/ 6 ply is enough for a comfortable ride coupled w/ nitro air, good choice for me...this will be my next replacement once my tires is worn out.
