Results 41 to 47 of 47
March 4th, 2014 04:33 PM #41
March 21st, 2014 08:57 AM #42
Could you pls explain a bit the#8...The R&P pre load adjustment. I had complaints regarding some rattling sounds somewhere in the front part of the suspension so they took out the R&P and added grease in it.
For those more mechanically gifted, is this solution safe? Thanks!
BANNED BANNED BANNED
- Feb 2011
- 101
March 22nd, 2014 03:30 AM #43^ wow so many problems for the accent. does the new accent crdi share the same parts / suspension as the accent sedan gasoline? kukuha pa naman ako
March 22nd, 2014 08:49 AM #44
As with any other brand/model, there are always defects. The important thing is if they won't ignore or give excuses. What's good w/ Hyundai, is that after verifying and diagnosis of the symptoms, they would right away give their honest assessment and if neede, replace the part.
May 13th, 2014 07:58 PM #45
Update for everyone:
Hyundai Shaw replaced yesterday the steering yoke and replaced it with an improved part that came in fresh from Korea and the steering rattle is finally solved. Steering tension also improved, a lot more stable on high speed.
May 13th, 2014 08:03 PM #46
Rack and pinion pre load adjustment is ok, however, they need to replace the steering yoke because it is where the rattling sound emanates. Try hyundai shaw at least they already know what the problem is
May 13th, 2014 09:51 PM #47
Hmmm di na mention hyundai sucat.
My 6mos old dcvvt accent had her front and rear shocks replaced thru warranty. Wala ako naging problema except yung front kasi tinamaan ng pasko. Delayed ng two weeks.
So far daily drive to work at 8k wala naman iba problema. Parang kinakabahan ako sa accent ko ha. Kasi yung vios ng wife ko for almost 4 years eh rear shocks lang pinalitan. Wala pa major problem
Posted via Tsikot Mobile App
I don't know why people continue to try and take Kennon Road from Rosario. Its perpetually being...
2023 Toyota Wigo
