Page 76 of 85 FirstFirst ... 2666727374757677787980 ... LastLast
Results 1,501 to 1,520 of 1696
    #1501
    Quote Originally Posted by kircchoffs View Post
    mga sir for 10K PMS na po ako, eto yung ginawa kong option para mabawasan naman yung total cost. ano pa po pwedeng tanggalin?
    Engine flushing, windshield washer, gasket drain plug. Yung stop squeal, iuwi natitira for next visit.
    Oct 2015
    #1502
    thanks sir. gusto ring malaman if pwede na rin akong magpalit ng fuel filter
    Sent from my MI 3W using Tapatalk
    #1503
    Sa pagka alala ko, every 20k pinapalitan yung fuel filter at water sensor sa PMS.
    Apr 2011
    #1504
    Speaking of fuel filter and water sensor, does anybody know the part number of the water sensor? I'm trying to compile a list of PMS part numbers for easy reference.
    #1505
    Part n0. for the water sensor-diesel filter of the Accent diesel is 31921 25000
    Air filter is 28113 1R100
    A/C filter is 97133 2E210
    May 2015
    #1506
    Hi guys, i observed a liquid leaking underneath the front passenger area, i tried to touch it and think that it is water. I have the accent diesel btw. Just went to the casa this morning and they said it is normal and it is the aircon drain, something like that. Do you guys experience this as well? I would understand if there is some leaking after a long drive but this also happens even if i drive for just 5 mins. Thanks in advance.
    Oct 2015
    #1507
    Baka sa aircon lang yan sir.. try mo e on ng off ang aircon kung may tutulong tubig...
    Sent from my SM-E700H using Tapatalk
    May 2015
    #1508
    Quote Originally Posted by dishcom View Post
    Okay, subukan ko.
    Jun 2011
    #1509
    karamihan nakikita ko accent nagpopost ng pms nila, sa grand starex how much kaya
    Oct 2015
    #1510
    thanks sir from 11K to 4K na lang nagastos ko for 10K PMS.
    Apr 2011
    #1511
    Thanks, bloowolf!
    Jun 2011
    #1512
    Good pm. Nag text ako sa papa PMS'han ko, I asked them kung ano gagamitin nila for my change oil sa starex ko. Sabi sa akin ang brand is S-oil from korea. What do you guys think? Pero tinanong ko din naman kung pwede magdala ng sariling Oil, at ang sabi naman ay Yes pwede. Okay na ba yung oil nila? or kung bibili ako like kung sa shell, anong brand bibilhin ko duon? fully synthetic for diesel. Salamat sa sasagot.
    Apr 2011
    #1513
    Quote Originally Posted by JonJon Villegas View Post
    Good day sir JonJon. AFAIK Casa will charge you corkage fee if you bring your own oil. better confirm with them. As for oil coming from outside, Hyundai engines usually require ACEA B4 or API CI-4 oil. Personally, I use Zic X7 for my Accent CRDI. It costs around 1500 for a 6 liter jug. It is labeled as fully synthetic pero since mura, kahit palitan every 5k - still affordable.
    Jun 2012
    #1514
    Gray market din ako bro. Sa hancars. Zic x7 ang gamit ko. Di naman ako sinisingil ng corkage. Malaking kamurahan. Although ayaw ako payagan sa oil filter, oks lang
    Oct 2015
    #1515
    nung nagpa PMS ako pinayagan din ako magdala ng sariling oil, nagulat ako tinanong saken kung may dala akong filters sinabi ko na lang next pms na lang meaning pwede ring magdala ng filters madaling kausap yung casa
    Jun 2011
    #1516
    thanks mga Sir. How about HGMO? which is better? zic or hgmo? thanks again
    Its like comparing brands bro...
    Normally if its fully synthetic (eg. 5w30) ... they have almost identical performance. Go for the cheaper price. Same protection. Di ka naman nasa race track hehehe
    Korean Hgmo I think is Zic. But Philippine Hgmo I think is shell.
    Jun 2011
    #1518
    thanks sir.
    eto pala website ng oil na ginagamit nila sa casa. Home | S-Oil
    meron na bang naka gamit nito?
    100k service
    Engine oil fully synthetic 5w30
    Engine oil filter change
    Injector cleaning with fuel additive
    Fuel filter change
    Check brake pads
    Change brake fluid dot4
    Rear rotors resurfaced
    Change atf oil sp4m
    Ac filter cleaned
    Underbody nuts and bolts tightened.
    Key fob battery replaced cr2032
    Tire rotation
    Engine feels hella smooth. I guess its broken in nicely.
    #1520
    80k PMS for my Accent hatch. Cost 7,300. Changed Fuel & oil filter, oil top up, cleaned brakes, tightened body bolts, cleaned A/C filter. Ang mahal dito yung 80k PMS labor, P3.5K.
Hyundai PMS
