Page 74 of 85 FirstFirst ... 246470717273747576777884 ... LastLast
Results 1,461 to 1,480 of 1696
    Nov 2015
    #1461
    Good day mga sir/mam!
    Just got my new accent 1.6 crdi mt and Im looking forward in my 1st PMS! Can u share your experience on your first PMS. Like how much po ginastos and ano mga ininclude sa PMS. Thanks po in advance!
    #1462
    Quote Originally Posted by Krisace View Post
    Wow may kasunod na car agad si Mazda 3 mo sir. Hehe. That was fast.
    Jun 2008
    #1463
    free ata ang first 1000 kms pms except sa oil & filter.
    #1464
    I just had my 75K PMS at Hyundai Las Pinas. Full oil change using 5 lits FS oil, engine flush, changed oil filter, changed air filter element, cleaned a/c filter, miscellaneous charges cost P7,300.
    Had my 95k pms. The usual.
    We removed the rear shocks for checks. 2 bolts on each shock and they were fine.
    Muffler had some issues. SA and mechanic changed the muffler in 5 minutes. Warranty replacement. If out of warranty its around 30k converted.
    The stabilizer bushing was bad. Hopefully tomorrow it(whole stabilzer bar) arrives. Bad roads here.
    Kudos to my hyundai crew 😊
    Mar 2016
    #1466
    Good day mga Ka-Tsikot, I Just bought my new 1.4 Accent CVT at Hyundai Alabang then naginquire ako sakanila for my 1k PMS. Nagquote sila ng 4.8k sakto lang po ba yun? Newbie palang po. Salamat po!
    Apr 2011
    #1467
    Quote Originally Posted by Tricioman_ View Post
    Sounds about right. Check for optional things that you can remove para bumaba pa (like engine treatment, fuel treatment, etc)
    Apr 2011
    #1468
    So I ditched casa service (along with my so called "warranty") and took my car outside to a Bosch service center for my 30k PMS (2014 Accent crdi Hatch MT).
    Here's the breakdown of cost:
    Zic X7 Fully Synthetic Engine Oil (6L jug) - 1,490.00
    OEM Oil Filter (from Goodgear) - 290.00
    OEM Air Filter (from Goodgear) - 290.00
    Labor - 250.00
    Total = 2320.00
    Vs Casa
    HGMO 6L = 4068.00
    OEM Oil Filter - 670.00
    OEM Air Filter - 780.00
    Drain plug washer - 40
    Labor - 1478.00
    Misc - 300
    Total 7336.00
    less One Hyundai Discount - 296.8
    Net - 7039.20
    Savings - 4719.20
    At this rate, I will be able to have enough savings to replace even my turbo charger should it go kaput before the warranty expires.
    Brad technique with after-sales is having good relationship with your service adviser Aka SA.
    Not sure kung accessible ang service bays but thats one thing to keep in mind. Better kasi kung makita mo aginagawa ng mechanic.
    Laking gastos pag babayaran mo lahat ng nasa quote
    Read your owners manual kung ano dapat sa 5k 10k etc.
    1k. Minimal charges lng dapat..
    Pag fully synthetic oil every 10k dapat oil change.
    May 2015
    #1470
    Hi, need your advice. Just got my accent sedan, nagpa.quote na rin ako for the 1k pms. This is what is written:
    PMS CHECK-UP:
    Change oil &oil filter
    Inspect/ adjust drive belts tension
    Inspect all fluids level
    Inspect all electrical system
    Inspect / clean battery & test charging system
    Inspect/adjust tire pressure
    Adjust valve clearance
    Lubricate all door hinges
    Bolt tightening
    Body wash and vacuum
    PARTS & LABOR RATE
    Labor - free
    Engine oil semi synthetic - 2310
    Oil filter - 725
    Total = 3035
    Or
    Engile oil fully synthetic - 4290
    Oil filter - 725
    Total = 5015
    I asked if i can bring my own oil, they said labor would not be free and the labor fee is 1108.80.
    Which items are okay to exclude? Would it be best if i bring my own oil and pay the labor fee?. TIA!
    May 2015
    #1471
    Hi, i need your advice. Just got the accent sedan and nagpaquote na rin ako for 1k pms. This is what's written
    PMS CHECK UP
    change oil & oil filter
    Inspect/adjust all drive belts tension
    Inspect / adjust tire pressure
    Bolt tightening
    labor-free
    Semi syn engine oil 6L - 2310
    Oil filter - 725
    Total - 3035
    Fully syn engine oil 6L - 4290
    Oil filter - 725
    Total - 5015
    I also asked if i can bring my own oil, they told me labor would not be free and will have a charge of 1109. Any items that can be excluded? Would it be best if i bring my own oil and pay the labor? What are your recommended engine oil? I am from the province so i hope the oil would be easy to find here. TIA!
    May 2015
    #1472
    Hi guys, need your advice. Just got the sedan and nagpa.quote na rin akk for 1k pms. This is what's written:
    Inspect / adjust all drive belts tension
    Bolt tightening
    Labor is free
    Semi syn oil - 2310
    Oil filter - 725
    Total - 3035
    Fully syn - 4290
    Oil filter - 725
    Total - 5015
    I asked if i can bring my own oil, they said labor would not be free and the labor fee is 1109. Which items can be omitted? Best to bring my own oil and pay the labor fee? Any recommendations for the engine oil? Hopefully easy to find ones as i am in the province. TIA!
    Bring fully synthetic oil 5w30. Sabihin mo babalik ka after 10,000km.
    Apr 2011
    #1474
    Quote Originally Posted by olympus View Post
    Bolt tightening
    Labor is free
    Semi syn oil - 2310
    Oil filter - 725
    Total - 3035
    Fully syn - 4290
    Oil filter - 725
    Total - 5015
    If you frequent Quezon City, meetup with Rome and get Zic fully synthetic. AFAIK it only costs 800 for a 4 liter jug. Then just pay for the labor. Do they allow you to bring materials? OEM oil filter from goodgear only costs 290 pesos.
    Apr 2012
    #1475
    Quote Originally Posted by airolynx View Post
    The 800 is just semi synth
    Sent from my LG-H818 using Tapatalk
    May 2015
    #1476
    Unfortunately im in CDO and i would be looking for your recommended oil here. I think they will also allow me to bring the oil filter, if i can find one here.
    May 2015
    #1477
    Il take note of the oil. Is it okay to skip the 5k pms?
    Apr 2011
    #1478
    Thanks for the information. Still affordable even if you change every 5k kms.
    Apr 2011
    #1479
    Goodgear ships items through LBC. Give them a call or text at: 0928-524-1198(Smart) 0917-510-4368 (Globe) 0923-717-9722 (Sun). I transact with their staff Eric. Okay siya kausap. They have OEM parts. Maybe they can even ship you oil.
    Apr 2011
    #1480
    If your oil is fully synthetic, go ahead and skip the 5k oil change but not the 5k PMS meaning you still need to replace your oil filter. But recently I got into the habit of just using semi synthetic oil (Zic X7) with the correct viscosity and change every 5k kms. It just doesn't feel right replacing your oil filter but not changing the oil.
Hyundai PMS
