Turbos really do make a whining sound esp. when turning at very high speeds (in excess of 10,000 rpm ang speed ng turbo). Maybe you have not had a turbo vehicle before.![]()
Pero irritating talaga sya...as in ang ingay. Nilalakasan ko na lang ang Stereo para di lang marinig....Yes sir Otep, first time owning a TurboFirst time owner din po ng diesel engine...noobs
share ko lang story ko from the other thread...
update ko lang sa trip ko kanina.
Sucat to Tagaytay
Tagaytay to Sucat trip.
Filled to the brim at Shell Sucat Road with Shell Unleaded (41 pesos only per liter btw).
126.2 kms
after going back to Sucat, same gas station, same gas pump...filled to the brim again.
Total consumption 4.99 liters
- 2 passengers plus heavy subwoofer at the back
- cruising speed at 65-70 kph
- top speed at 100 kph for about 30 secs only
- 4 stop overs in total ( off-on ang makina )
- downhill I don't step on the gas anymore, alalay lang sa brakes
- no aircon at all
- odo at 4500++
- was really aiming to beat my Manila - Tagaytay record of 19 km/l
126.2 kms
4.99 liters
_________
[SIZE="5"]25.29 km/l[/SIZE]
Hmmm...very subjective din kasi ang symptoms. Dapat marinig muna bago ma-assess. Hindi naman belts yan?
Nope, hindi belts. its the same noise that you will hear if there is a crack sa rubber ng mga doors...Anyone who can hear it think that its with the doors. One by one, tinakpan ko ang door sa likod, then passenger side then sliding, including windows, one by one. Pero same pa rin. Yung sa driver side na lang ang hindi ko pa nasusubukang takpan pero di naman doon kasi i tried opening it a little while driving at 70KPH, noise is still there.
i just discovered na pag nag maintain ka ng speed between 70-80kph e sobrang tipid ng ating 2010 sta fe.
typically ang range ko sa consumption based on the display is from 10-10.2 liter / 100 km.
last night umuwi ako from work around 230am at eto ginawa ko.
- reset the liter/km reading
- maintain 70-80kph as much as possible
- nung nasa subd na ko e ave spped ko e 20-30kph.
- voila pagdating ko ng bahay consumption ko is 6 liters / 100km.
distance ng house ko from the office is about 14km one way.
eto yung pic pag hinto ko sa tapat mismo ng bahay.
http://i1225.photobucket.com/albums/...g?t=1285159598
actually running with that speed will produce a very fuel efficient run kahit anong koche. mas na re-realize lang naten kasi at that speed naka engage na yung 6th gear both sa tucson at sta. fe. then the rpm is just at 1500~1750rpm. so best cruising speed yan na mag yield ng best fuel economy.![]()
kaso sa highway parang sobrang bagal naman ng 80kph, the R-evgt engine will just tempt you to go faster. haha
My tucson ReVGT did 6.5l/100kms from pque to clark, tipid sobra thats more than 15kms/l. Running 100-120, then occassional 160-170 pag maluwag
Our montero did 9.5km/l, sulit ang diesel
baka naman me butas na rubber seal ng windshield mo or baka meron kang nakainstall na roofrack or rainvisor sa doors that may produce whistling sound at highspeed.
OT: Sa GEN I Pajero namin. Yung mismong door seal ng passenger ang problema. So whether window up or down, andun ang tunog.
I'll check the Roof rack...yes meron ngan roof rack ang van ko. Try ko i-seal sa labas ang door sa driver side.
One thing I've noticed is that the noise starts when I shift to 4th Gear. I try to keep it slow mamaya pag-uwi at 4th Gear and see if has something to do with it. Will probably run it at 50KPH sa 4th gear to check.
yakuini, sa amin din sipol sound starting around 70 kph, tagal ko na din hinahanap, i really think its the roof rack.
I removed the roof rack yesterday and went to the office today, wind noise is still present. Waahh, saan kaya yun?!![]()
Will try to seal the hood naman mamaya.
Yakuini, we have the same problem.Kabibili ko lang din ng starex club 2001 last month.akala ko it came from the power antenna kse sira na hindi na bumababa.When I reach around 80 kph naririnig kna yung parang bukas na window yung sound.check kna rin yung rubber ng mga doors pro wla ako mkita na sira.
i own a 2001 tci starex,,, and i filled it full tank which is probably bout 55 liters because i dnt fill it up after the first click,, my odometer doesnt work,, anyways from paseo, santa rosa laguna,, we drove to bagiuo,, we left santa rosa laguna. at 11pm.. stopped at starbucks in petron NLEX for an hour,,then proceeded to bagiou.. arived there at 4am via kenon road.. then later in the day we drove around for an hour... then left bagiou at 6pm.. i didnt refill until tarlac.. when the fuel warning light startd to light up during hard acelaration. im not sure bout the distances... so for those who are in the know.. how is my milege?
