Ni reset ko na lahat, average tlga nasa 20 minsan nga 21 pa, 1200km+ na takbo kaka tune up ko pa lang semi synte, anyidea papanu pa bababa ang fc nitong 2.4L 4wd cvvt.Originally Posted by edquita
Malakas talaga sa gas yan 2.4L na 4WD pa. Premium pa kaya mabigat hahaha. 33PSi ang tire pressure nyan.
Mas matipid pa yung Genesis Coupe 3.8 V6 :hysterical:
Masmalakas nga sa gas yan 2.4l, yung sonata namin maslumalaklak kesa sa 3.8 genesis e. parehong matic
My tucson ReVGT did 6.5l/100kms from pque to clark, tipid sobra thats more than 15kms/l. Running 100-120, then occassional 160-170 pag maluwag
Our montero did 9.5km/l, sulit ang diesel
Ride: 2011 Accent (Manual Transmission
Displacement: 1.4L
Engine Configuration: Gamma 1.4
Fuel Consumption:
-City: 11 km/L
-Highway: 17 to 18 km/L (Speed not exceeding 110kph)
-Mixed: (13 km/L)
-Using 93 unleaded gasoline (no ethanol)
Tire pressure during the observation period was 29/28 rear & 30/31 front, I re-pressurize the tires just this afternoon to 33 on all 4 tires. (lintak na Shaw yan kala ko check nila pagrelease sa 1000km PMS last week)
Readily available na sa Accent yung km/liter, though its not that 100% accurate you can still use it for reference, as posted above 5.5/100km so it gives you roughly 18km/L...
Unless you need a very accurate data reading, then that will be the time you need the total km and total fuel liter used. hth
Actually, this was driving along commonwealth back and forth from my house and Phil. Heart Center. Max. limit speed is 60kph and at 1500RPM.
Share ko lang din.... Inabot ko yung 5.2km/100L FC last week while driving along NLEX going to Isabela (7PM). Speed average at 90-100kph at 2400-2500RPM. This was only at NLEX going to SCTEX. At SCTEX, just to test the power of my Accent, I reached 150kph at 3600RPM and 5.8km/100L FC average. 4 adults, 1 baby and trunk was full of bags were the load.
By the way, I gassed up 18L in Shell NLEX and it reached Santiago City. I think the odometer was around 320km....
[QUOTE=andretti;1837476]Readily available na sa Accent yung km/liter, though its not that 100% accurate you can still use it for reference, as posted above 5.5/100km so it gives you roughly 18km/L...
Unless you need a very accurate data reading, then that will be the time you need the total km and total fuel liter used. hth[/QUO0TE]
Sir, pls pedeng request naman ako to accurate as much as possible, any way you are always using ur car di ba, so pls try to get full tank then please run till 50km but make sure make it zero first the trip, then once you reach 50km, fill the gas till full tank, and check how much liters consumed, ok thank a lot buddy, So I can decide to buy on this coming Dec. thx again
Sir, paki ulit, tinuturuan mo ba ako or inuutusan since it sounds that way...hehehe
BTW madami nang discussion on how to have an accurate FC reading, backread ka lang...
*jaymzofmetallic, baba ng FC mo bro.
Ang bababa ng consumption ng accent nyo. Yang 5.5l/100km hindi ko pa nakikita umappear sa accent ko. Laging nasa 12-14l/100km hehe. Lagi kasing city traffic driving. Last manual computation ko 5.8km/l city driving.
