Results 41 to 50 of 82
- Jun 2008
- 1,741
March 15th, 2010 09:14 AM #41Several Hyundai/kia crdi engine were reported to have this problem. Ang naging problema ay blocked/clogged egr. Simple cleaning lang ang solusyon. Di ka na gagasto kung DIYer ka.
March 15th, 2010 02:08 PM #43
That black smoke might be a cause of defective fuel injectors,dirty or poor Quality of fuel,injection timing problem,
clogged air filter >> happened to me while driving my sis '08 Santa Fe from the south in Quirino Highway (between bicol region & Quezon province), almost mid day and sobrang maalikabok ang kalsada & there was an ongoing road construction..
Napansin ko n lng d n ako mka-overtake s vios (imagine that?) & zero visibility n behing my rear windshield coz of smoky exhaust so i stopped immediately & checked my airfilter & found it thoroughly clogged.. Good thing my spare air filter akong dala..
Note: Tip ko lang for those who have their airfilter changed in casa, pwde nyong hingin ung old filter & linisin na lang s bahay with compressed air or labhan lang & keep it in the car.. No one knows when you encounter a situation like mine & magamit mo yan in an emergency...
March 15th, 2010 02:32 PM #44
- Nov 2009
- 3,482
March 15th, 2010 04:20 PM #45
March 15th, 2010 05:03 PM #46
March 15th, 2010 06:46 PM #48
Only my point was you can use it in an emergency..On my case,used it only for short period of time til we get home safely & for engine not to suffer too much rather than running your engine without filtration from dust/airbourne small particles on its air intake..
Wala kang choice but to use the old spare,your miles away from the casa..
Better bring with you a new one..
- Feb 2010
- 336
March 30th, 2010 01:21 AM #49
mine was a starex jumbo crdi 2006 w/ 80,523 odo reading when this unfortunate incident happen: note: warranty expired just recently
travelling along the stretch of sctex, the van gradually lose acceleration from 120kph going down and i feel as if i was left behind by those vehicles i used to overtake...when the tachmter reach 5kph, slight jerking coupled w/ near engine stalling (just like horseback riding) as if mauubusan ng fuel started (w/ engine malfunction icon on the panel lighted), buti na lang malapit na kami sa casa
the culprit: loose nut on injector #4 as diagnosed by the casa, fixed by tightening it and adjusting ECU becoz of the lighted engine malfunction, cost - 546 petot..
here comes the worst part, while on my way back thru NLEX the same problem aroused again this time it was already past 10pm and the casa is closed (no choice but to leave it at their parking lot)
again the diagnosis: injector #4, casa cant determined the cause but their boss experience the same when refilling fuel at unknown station somewhere in the province while mine has no fuel problem or whatsoever,
the remedy: interchange injector #4 w/ injector #2, clean all the injectors even test all the injector's nozzle pattern which is all normal, adjust again the ECU to turn off the engine malfunction light, cost - free (becoz after i got home i sent a disappointing email to HARI explaining what happen and the next day i receive a call from the casa telling me that their doing everything to fix problem, i guess that help.
i hope this helps whenever problem like this occurs...cheers
April 5th, 2010 07:33 PM #50
anyway, some are saying that maintenance costs of the diesel CRDi is quite high compared to the gasoline counterparts. makakatipid ka daw sa consumption, pero sa maintenance ka mapapamahal?
how true is this sa mga CRDi owners dito?
just seen a 10th gen cross 200,000 miles on reddit. is this a unicorn or has the cvt been proven...
All New 2016 Civic
