Page 2 of 2 FirstFirst 12
Results 21 to 40 of 40
    Quote Originally Posted by mda_ View Post
    at least buo pa yung passenger cabin nung kotse even after crashing at 100++ kph. hirap din niyang "sudden acceleration" issues na ganyan, yung iba driver error lang talaga, yung iba after a lawsuit lang. toyota, mitsubishi have had their shares of this, even honda may actual person na kilala ko na nangyari sa kanya (2000 civic ek). best is to know what to do if this happens to you.
    dapat yung binangga na lang nung driver yung unang kotse nung pa-accelerate pa lang siya, kung wala na talaga siyang control
    Tama. At least hindi na sana siya umabot ng 80MPH.
    kaya important na din ang dashboard cam ngayon. para recorded lahat ng nangyari.
    true. sana isama na as standard equipment especially sa PUVs and trucks.
    sana meron ding 'pedal cam' para mavalidate nga yung SUA
    I would have gone for the first wall I would see. At the start of the acceleration, you could hear the driver apply the handbrake. I would still wonder though why would the car manufacturers let ECU access to accelerate the car. I know they do that to increase/decrease idling but there should be a hardware to limit any acceleration initiated by the ECU.
    i wonder what would have happened if the driver shifts the gear to P immediately.
    but everything happened so fast na its difficult to decide on what to do na.
    Feb 2012
    Mythbusters tried this one.. The car would just coast when put into reverse or park during such speed.
    Jun 2010
    Quote Originally Posted by EA622 View Post
    actually, kahit sa N lang pwede na dapat eh. the engine would just rev like crazy
    Just curious, ano kaya age bracket ng mga na involve sa SUA na ito.
    Sa first video "elderly Korean couple" yung sa ibang video kaya?
    Karamihan nga ay middle aged to senior citizen. hmmm
    Jun 2006
    once i accidentally changed gear to reverse on my corolla lovelife a/t while running at 60kph. The engine just died, had to tottaly switch off the key at full stop to restart it again.
    these are the reasons that i would still buy a manual car for as long as my left leg can push down on the clutch pedal.. i read this article and it got me thinking..
    Manual Transmission? What
    put the gear in N, R or P. pull hard on the hand brake and IF the foot brake still works, stand on it (sabi sa ibang forums the footbrake does nothing during these SUS instances).
    last resort is to put the gear in N and switch off the engine, then try to start it again with the vehicle still moving. stopping the engine results to loss of power steering and brakes so you should only switch it off when all else fails. you'll need to start it again to regain power steering and brakes.
    Jun 2006
    Nangyayari din ba itong SUA sa mga auto na walang cruise control?
    Jan 2009
    Here are a couple of Kia K5's (of course, Hyundai owns Kia) that appears to have the SUA bug.
    No audio:
    Same model, different car. You can hear the driver seemingly stomping on something. It could be the brakes or the accelerator pedal (maybe he's trying to free it, thinking that it's physically stuck).
    CCTV1 view
    CCTV2 view
    Aug 2004
    A stuck pedal assembly or trapped pedal is always the most likely scenario in these situations, if there's a physical (non-driver) cause. If you hear them trying to unstick the pedal, that's it.
    The question here is whether those are cable-throttle cars or electronic throttle ones. If it's cable throttle... then it's possible the cable got stuck. If it's electronic, no. The answer will lie elsewhere... either with the mat or with the actual throttle assembly sticking.
    Jan 2009
    I think there's one apparent description missing in most SUA incidents. In that, the throttle wasn't stuck at 1/4 or even 1/2. From the roar of the engines, they seemed to have been 'set' to WOT, whether accidentally or uncommanded. No driver in their right mind would go WOT in most of the circumstances in the videos above (ie. turning right at a tight corner, at a traffic light but behind another car, etc.)
    Even while driving on the highway, unless you're actually doing spirited driving, most drivers are in the habit of feathering the gas pedal. So if it went from that to WOT without the driver commanding it, it could be the throttle servo, ECU, or the throttle position sensor (either on the pedal or throttle assembly).
    Now, an epileptic driver is another thing.
    Feeling ko fake yan. I doubt mag full throttle yun sudden acceleration. And besides, bilis lang naman solution dyan, the letter N.
    Jun 2009
    before this accident, may news na rin sa yahoo na may gagawing batas sa US na mandatory na ang car black box. hindi ko lang matandaan kung aling state. nabasa ko rin na ngayon pa lang pinoprotestahan na because of, as usual, privacy issues..
    Aug 2010
    *Press hard on break*
    *Press hard on gas*
    Uhh.... what seems to be the problem here?
    Jul 2011
    im digging if there's a video of CCTV on the net with this news 4 teens killed in Ayala Alabang car crash | ABS-CBN News
    and it led me to this thread.
    maybe it is really time as this article says Is it time for a car black box? | Inquirer Business
    Quote Originally Posted by MrQ5 View Post
    I think that is an excellent proposition as long as it won't cost an arm and a leg. That would clear a lot of things.
Dashboard Camera Catches 80 MPH 'Sudden Acceleration' Hyundai Crash
