Hahaha!
Bros.,- I don't blame you guys, if you do not trust me anymore....
Look at my perception of the "yosi window",- mali pala after all of these years. I went down just to verify with a HARI VGT unit here in the office,- iyon nga the small window is present on both sliding doors....
Now, let me try to remember what I've been smoking for the past 4-5 years.... :hysterical:
16.3K:shower:
Eb na yan para ma test drive na tci ni cvt hehehe. Sa totoo lang matagal nako na curious dyan sa tci a/t mo bro. No offense meant bro pero feeling ko kasi medyo kapos na yung tci m/t, tapos a/t pa yung sayo. Iniisip ko parang yung 2.0 engine ng 2003-2004 camry big body. Hirap humatak yun sa laki ng kaha niya, kaya discontinue ni Toyota yung 2.0 engine and naging 2.4 na yung base engine in later models.
mga TCI m/t users...wl bng adjuster ng clutch ang GS ntin?
sinilip ko n s clutch pedal at secondary clutch cylinder pero wl tlaga akong makita
Well bro relativity issue naman yan. Di naman nakakabitin ang power ng 2.0L on the heavy '03 Camry body. Toyota low to mid end Torque made up for it IMO. Stock 15s still spin at sudden low speed jabs at the throttle so kaya naman ng engine.
Perhaps the only times nabitin ako were when i replaced the stock airbox with an open type - too much air, it didn't like - and when i was on 20s as in my avatar. Kaya naman ang 18s. Will not win drag races but is comfortable at mid to high speeds.
Shempre the 2.4 would have been better.
Bro.bratski,- in that respect, I can agree with you. I also drive the Gen4 TCi M/T of our company and am surprised by the response of the engine....para ngang kapos....lalo na sa low gear...
Baka nga lang mas maganda ang gearing ng A/T (??)......
"Enigma" na nga lang kaya ang maipangalan ko rito, instead na Aircraft Carrier....
16.3K:shower:
Was commenting about this when i had a chance to drive my bro's Camry, it's an 03 model 2.0g, naka 18's kasi yun and sa akyatan kinakapos.
I agree with you about the different torque specs for manual and matics, the previous gen3 crdi m/t has only 330nm of torque while the a/t 360nm. This is to compensate the power loss of the matic torque converter. Not familiar with the gen4 tci m/t and a/t though.
Bro CVT, l think the m/t has about 230nm of torque, how about your a/t?
i had my 5k pms kanina inabot ng 3,235pesos change oil/filter,tbb,lubricate hinges and suspension
6ltrs semi synthetic oil (voltronic)= 2,100
free labor
oil filter=620
penetrant=175
drain plug gasket=40
misc=300
