Where can I find 195/50/R16 alloy wheels for my Hyundai Accent hatchback to replace the stock 170/70/R14?
I don't want to void the car warranty.
Di naman ma void warranty. You can go up to 17 or 18, basta up to spec ang overall diameter ng tires, not going beyond 3% of original. 175/70/R14 diameter is 602mm. Maximum diameter mo is 620mm. Although sabi ng Tire Center, si Marika, yung magandang receptionist na ex ko sa panaginip, mahirap saw humanap ng 16's
Actually yung Hyundai dealer ko advised me they will definitely void the warranty if I go beyond yung listed tire spec sa sticker which is up to 195/50/R16 lang, kahit na alam ko pwede higher.
Guys hingi lng ako ng suggestions. Naglagay ako ng isang 12inch subwoofer s koche ko, mlkas sya bumayo tska mgnda tunog nya ksi sealed ung baffle ko. Ngaun, may mga nginig or garalgal na tumutunog s trunk or back seat pg mlkas n ung sound. Ano kya dpt gawin or ilagay? Hyundai accent 2014 sedan low end ung koche ko. Thanks
Guys, I've set my sights on a set of mags with the following specs:
15x7.5J
ET 30
I plan to pair it with a set of 195/60/15 tires with a with of 7J.
I chose bigger tires since I really hate scraping the humps in our village. My questions are:
Will the 7j fit the 7.5j wheels?
Will it cause any safety issues since I travel the expressways daily
Will it cause rubbing of the fenders & shock mounts?
Any inputs will be highly appreciated.
I installed 195/50R16 tires with 16x7JJ ET40 alloy wheels on my Accent hatch. Couple of issues: The wheels just barely cleared the brake calipers. Also, the tire side wall extends a bit out of the wheel well so mud gets slung onto the fenders.
A 7.5 inch width rim is too wide for the cross section width of the tire you plan to use (195 mm or 7.67 inches). Per my research a 6.5 inch rim is the ideal match, but you can stretch it out to 7 inches at most.
Thanks for the reply bro. Actually, I did not push it with the wheels anymore. I was really concerned that it will scrape onto the shock mounts & might have issues with the warranty of the car. I am now looking for a15x 6-6.5JJ wheel instead.. It's a shame cause I really like the design
I have done an EGR block the first week i got my nissan navara (the very first mod i made on it) and six years down the road and my navara still pulls and punches like a sledge hammer. No mechanical problems thus far.
Has anyone done an EGR blanking mod on the hyundai accent CRDI? how easy or difficult would it be to do on a CRDI accent (it was very easy to do on the navara)? any long-term observations for those with EGR blanking mods out there?
Mga Sir, Tanong ko lang po kapag ba pinalitan ko stock HU ko ng Pioneer HU A/V sa labas maapektuhan ba warranty ko?
2011 sedan ride ko and I find na napakalambot nung stock springs. Meron bang alternative dito? Yung newer models ba firm na yung springs?
Sent from my SM-G925F using Tapatalk
Btw changed the shocks to nitro, nagimprove ng konti.
