Page 4 of 16 FirstFirst 1234567814 ... LastLast
Results 61 to 80 of 1294
    Nov 2007
    Quote Originally Posted by joeyboy88 View Post
    Thanks Meikey. Your inputs are gold bro! Really appreciate it. I decided to stick with 16" rims. All I need now is to find a rim design that I like. Medyo limited pagpipilian sa size 16. :-)
    Ito yong mga personal favorites ko. Ito din yong mga pinagpipilian ko dati. And end up getting Lenso SC5, para naman at least yong dating is medyo conservative at the same time sporty tingnan..
    SC05
    SC01
    PD1
    And if medyo malalim yong budget, w/c ayaw na ni mrs., ito sana:
    Disclaimer: I am not promoting these products nor ibinebenta tong mga produktong ito!!! ehehehehehe
    gusto ko yung pd1. maganda. at least sa pix. ewan ko lang sa personal.
    Nov 2011
    Quote Originally Posted by meikey View Post
    SC05
    SC01
    PD1
    Very elegant yet sporty choice bro! I was wondering... papano kay papalakasin yung headlights without resorting to hid? Would really appreciate your inputs meikey. Guys, if you have suggestions too... please share http://5175.voxcdn.com/forums/images/smilies/agree.gif
    sir AFAIK may ibang alternative na bulbs na mas malakas sa stock halogen aside from using HID. Like Osram Nightbreakers, Philips Xtreme Power. Yan po magandang alternative if you don't want to use HID. HTH
    ^^ pero hindi po siya kasing lakas ng HID, pero you can see the difference from stock halogen bulbs.
    Nov 2011
    Quote Originally Posted by zel.chikot View Post
    Thanks sir zel :-)
    Oct 2004
    ^^ sir meikey,
    Medyo nosebleed ako nung binasa ko instructions hehehe. You lost me at red wire. Bilib talaga ako sayo. Pag ganyan wirings na pag uuspan i leave it to the pros. Pinaka technical na alam ko lang is pag install ng head unit.
    Nov 2007
    hehehe, actually sir nong una, yong installer ko w/c is from my dealer, hindi na nila talaga alam paano i-integrate yong cluster indicator, kaya one good thing na meron ng wiring harness & schematic diagram sa hmaservice.com.
    Kaya, ang ginawa ko, doon ko binase yong installation, and used my electronics knowledge to finally integrate the cluster. Actually sa HeadUnit, doon ko na rin binase kaya nagawa kong iD-I-Y yong headunit installation ko.
    Actually, babasehan mo lang yong wiring harness diagram. As posted in the picture, yong wire no. 14 sa diagram, yan yong linya to light up the indicator. Sa pagkakaalam ko, as well as what we have performed on my unit, gumawa sila ng separate circuit using separate relay.
    sa foglight installation on my accent, this is what we did...
    Yong relay has nos. 30, 85, 86, 87 (Bosch Relay)
    Yong no. 30 (Power Source), tap it to the IGN. (make it sure also na you had you 10Amperes Fuse na nakaseries on that line)
    * Ang mangyayari nito, sa OEM setup, the Foglight will only light up when the key is turned to ON Position or the engine is running. Some installations, they tapped it to the battery. Remember that Foglights, on stock configuration has a total of 54Watts (27 on Left, 27W on Right), kaya tendency if you leave it opened while the power is not coming from alternator may drained your battery.
    Yong No. 85, tap it to the Park Light's Ground Terminal.
    * Ang mangyayari is the fog lights will light up only if the parklights is switched to ON Position and when the Ignition is in ON Position. I saw other installations, na itatap nila ito on the body ground. What would happen is independent yong Fog Lights mo sa Park Lights w/c is not advisable.
    Yong No. 86, tap it to the Multi-Function Switch (Positive w/c pin no. 2 sa multifunction switch), yong Pin No.1 ng multifunction switch, ibody ground yan... Kung mapapansin mo sa diagram, naka-tap cya sa Low Beam ng Headlight, kasi sa US & Canada, the fog lights will turned off if naka-high beam, w/c makes sense naman...
    Yong No. 87, positive out na yan, connect it to the positive terminals of the Fog Lights, Negative terminals of the Fog-lights, pwedeng i-Body Ground.
    And lastly, tap the #14 wire sa instrument cluster harness (As seen on my earlier post) to the #87 Relay. Mas mabuti rin na lagyan mo ng resistor (recommended is 560ohm 1 Watt +- 10% Tolerance na Resistor) ang linyang yan to suppress current surge from that line. Though it would also generally lower the light intensity ng LED by a bit, but not that much...
    Ito pala yong wiring harness diagram ng multifunction switch:
    Sep 2006
    parang may nabasa na ako dito na naintegrate ng MASPRO sa dashboard ng Accent ang fog light. Or baka naduling lang ako sa dami ko nabasa.. hehe
    mga pinalitan ko na sa Accent:
    Horn, Alarm at nagpalagay ng backup sensor. sunod ko yung HL, mudguard and shark fin antenna kung may available na dito sa atin.
    Aug 2011
    Quote Originally Posted by dopamine101 View Post
    sir dopamine101, ano itsura ng terminal ng horns? balak ko rin magpalit eh, parang boses alam mo na ang tunog... binaklas niyo po ba yung bumper? Baka pwedeng makahingi ng tips :D
    Nov 2007
    when it comes to horn upgrades, kailangan talaga tanggalin yong bumper. But it shoulden't give you much of a problem as this is a common procedure lang ng mga shops.
    Sep 2006
    yes kailangan talaga ibaba ang bumper. kay jemson ko na pinakabit para isabay sa back-up sensor and alarm.
    Quote Originally Posted by erj22 View Post
    Jan 2011
    Ako din, parang nabasa ko din yan...I was assuming that Maspro is installing the Fogs with the OEM switch.
    Sep 2006
    Quote Originally Posted by andretti View Post
    Maspro installs accent foglights with oem switch and and enables the foglight dashboard lights too. i had it installed in my car 2 days ago, just look for Benjie. and for those who have 2 din china gps HU, Benjie can also help you in activating the gps using Garmin maps !
    * sir meikey
    re: fog lamp installation
    1. sir meikey ask ko lang sa iyo since na disect mo na yung wiring under dash...nakita mo ba kung existing yung front fog lamp relay (RLY2 - this is a pcb mounted micro relay located at the rear portion of I/P junction box, see SD100-1)
    2. and also existing din ba yung front fog lamp wiring harness socket EGG43 (front fog lamp LH) and EGG53 (front fog lamp RH) located on left/right side of front end module just beside the fog lamp itself. (see CL-1)
    note: all reference came from hmaservice (accent (rb) > 2012 > G > 1.6 GDI u.s. version)
    thanks in advance sir meikey
    toiboi-silver m/t-may 19-valenzuela city
    Nov 2007
    Yong sa relay ng RB sir, hindi ko na hinanap but I did take note on that...
    The wiring harness and the H2 sockets, yes they are existing sir... In fact yon na yong ginamit namin para hindi na bubutas pa sa firewall. Ang ginawa ko, I bought my own relay, and tapped the stock harness to my relay.
    Ang pagkakaiba kasi sa setup ng RB than most Asia Pacific released units, yong positive actuator signal ng relay, nakatapped sa HeadLamp Low Beam Positive, passes through multifunction switch for switching, then terminated to pin #86 of the relay, Pin #85 (Negative actuator signal ng Relay) is tapped to body ground.
    Ang mangyayari nito sir, is when you set your headlights to high beam, yong fog-lamp would be off, pagbalik mo ng low, tsaka iilaw naman uli. Although it makes sense naman kasi when your on high beam, I think the illumination is more than enough that you no longer need that extra illumination coming from your fog lights.
    However most Asia Pacific setup kasi, nakatapped sa parking lights yong fog-lights. However, foglights will light up only if and only if the IGN is in ON position & the park light is switched to ON. This is to protect your battery from draining out if you leave your park-lights on while the engine isn't running. Kaya if you leave them both park lights + fog lights open, then you turned off the engine, the fog lights will be off, however the parking lights remain open...
    Like I said on previous post, you have 54 watts of total load for the fog lights, now if your fog light's power source is tapped directly to the battery, and you leave it open for a significant amount of time (park light + fog lights), tiyak drained yong battery mo.
    Apr 2008
    Accent Owners Good Day!
    I would like to ask several questions about the specs of your new toy, and hope that this is the correct thread since I am shopping in for a car in this price range. And the killer looks is definitely a plus.
    For the M/T owners and in the know are these deal breakers?
    > Lack of steering wheel tilt adjustment
    > The lack of safety components like ABS and airbags
    > Rear seats fixed
    > Hubs instead of Alloys
    Appreciate all your inputs.
    Apr 2008
    Also, armrest po ba cya?
    thanks a lot for the input sir meikey. base on the diagram (SD924-1) it is clearly indicated that fog lamps will turn on (assuming IG2 is switch to on) only if the low beam is switch on. (pin1 is shorted to pin14) of the multi-function switch. and if you set the headlights to hi beam the path is diverted to pin 13 that trigger the hi beam, low beam and fog lights turns-off. so kung isasabay ang fog lamps sa park lights pin 1 should be cut from pin 14 and tapped it to pin 7 of the multi function switched. fog lights will only turns on only if the IG2 is set to on position. if IG2 is off then park lights lang ang sisindi.
    madali intindihin yung diagram pero ang hirap pala i trace yung wire under dash. yung rear ng I/P junction box may cover pala di visible yung mga micro relay. yung iba components like yung mga fuses 10amp and 50amp meron naman pala. project ko kasi ito by dec eh...
    salamat ng marami sir...mabuhay ka
    Nov 2011
    Ive read na walang alarm at keyless entry ang 1.4 m/t. Kapag nag pa install outside hyundai mawawala ba warranty? Overpricing kasi sa kasa 7,500.
2011 Hyundai Accent Modification/ Accessories made
