Page 51 of 61 FirstFirst ... 41474849505152535455 ... LastLast
Results 1,001 to 1,020 of 1208
    Apr 2004
    #1001
    Quote Originally Posted by maxhedrum View Post
    With your knocking, check with your casa if you have Euro 2 update. After the update, you will still hear hear it occasionally or none at all using Shell Unleaded. Vpower is a waste of money in my opinion.
    I'm inclined to believe that maxhedrum is correct with regards to the fuel type. It's weird by my fuel consumption seems to be higher when using 97-100 RON fuels. I've not completely gone down to 93RON but once, when my gauge was halfway empty, I decided to fill up using 93RON and was surprised that the FC improved and the engine was more quieter and responsive.
    I'll use up my gas first and try a full tank of 93RON. Let's see what happens next.
    Just an update also on the EURO 2 re-program done on the car - I still occasionally hear the knock. Pero knock na lang sya, hindi na knock-knock. Sounds like a single knock when the AT shifts. Not sure though if it will stay that way or if it will get worse. Under observation pa. Will pull out the fuse first to reset the ECU since I just put in a Hurricane drop-in filter.
    I'm still hoping a colder plug might completely kill the knock. Anybody tried this? If a colder plug doesn't kill the knock, will it kill the engine or screw up the FC?
    Jun 2012
    #1002
    is the 1.6 engine of the accent the same with the 1.6 of the elantra?
    and is the knocking issue not encountered with the 1.6 accent?
    thanks... (wala bang sariling thread ang elantra?)
    Oct 2008
    #1003
    google says they're the same...both mpi engines. no one has reported engine knock on 1.6 engine elantra or accent in this forum.
    Quote Originally Posted by taraki17 View Post
    Jun 2008
    #1004
    As ar as I know walang knocking issue ang 1.6L engine ng Elantra & Accent. Yes the same engine sila. Mas matipid yata ang accent kesa elantra due to lighter body, not sure though.
    #1005
    Quote Originally Posted by weisshorn View Post
    Hindi sila same engine. The Accent uses the older CVVT engine with 124 horsepower. The Elantra uses the Dual-CVVT engine with 130 horsepower. Iba rin transmission, 4-AT for the Accent and 6-AT for the Elantra.
    FC shouldn't be too different, but I'm pretty sure magiging mas matipid yung Elantra especially for long drives.
    #1006
    This is pretty interesting, despite all the issues that a few Accent owners have raised, the Accent is actually selling more today than it did a year ago:
    Astoundingly, more than a year since it was launched, the Accent is selling better than ever. They now average 674 units a month compared to the 345 per month in 2011, translating to a 95% jump.
    And just this morning I was thinking, "Sayang naman Hyundai, you already made a Vios-killer, but you kinda spoiled it all with shoddy quality and after-sales service". I guess Hyundai's still keeping it together after all. Sana lang they don't get too complacent about this and altogether ignore the issues that some of their cars have.
    #1007
    problem with hyundai, bagal nila kumilos...
    eh kung sana inayos na nila mga reklamo nung una palang, sana di na umabot ng ganito katagal
    Nov 2003
    #1008
    Thank you, Maxhedrum, for the advice. I actually did call the casa about the knocking issue about a month ago at 3K on the odometer. They did tell me to bring the car over for inspection. I did not do as advised thinking I'd just suck it up until the next PMS. V-Power solves the issue for now but I'd certain take issue with the knocking on the next PMS.
    Miguey, all accents here and abroad have issue with front/back suspension. Its too soft. Aftermarket is only solution.
    Jun 2012
    #1009
    Quote Originally Posted by andro0120 View Post
    I sent the car in today for its 1K PMS.
    I decided to stick with Semi-synthetic since I couldn't get myself to accept the fact that Hyundai's full-synth engine oil is rated 15-50w and I have to spend over 3K for it. Siguro sa next PMS, magdadala na lang ako ng 10-30w. I'm sure it will help with the fuel consumption.
    Anyways, I told the service advisor about the occasional knocking that I hear between 1.5K-2K RPM and asked them to make sure the ECM is updated also. Got there at 7am, car was serviced around 730am and was out around 1030am.
    So far, in my short driving stint, I have yet to hear the knocking sound that was present before. Tried replicating the circumstances when it would manifest previously, but did not hear it. Engine feels slightly more responsive but can not comment on FC yet. Pansin ko lang, pag nag full tank ko ng automatic stop, ambilis mawala nung first line ng gauge. Not the engine's fault though...
    Hi i'll send my car this saturday for the 1k PMS... Just want to ask regarding the full synthetic oil.. U mean na hindi ok ung full synthetic oil na nilalagay ni hyundai?
    And just curious... Ganu kalakas ba ung "knock" na naririnig nyo?
    Nag improve ba ung fuel consumption mo after the change oil? Mine kasi is 6km/L.. sobrang lakas for a subcompact car right?
    Apr 2004
    #1010
    Quote Originally Posted by AccentHyu2012 View Post
    On Motor oil:
    Not saying that their oil sucks, or that it's bad. What I was trying to point out was the fact that their "in house" fully synthetic oil was rated 15w-50. Although the value of fully synthetic oil is mostly because of it's composition and not it's weight, fully synthetic oils outside the casa that have lighter weights are basically the same price, maybe even slightly cheaper.
    For new cars, lighter oils help fuel consumption because it allows the engine to move more quickly vs heavier oils. Lighter oils also get to critical parts up on top of the engine faster than heavier oils, specially during cold starts.
    On Fuel Consumption:
    I have not driven the car enough to get a solid feel of whether the fuel consumption has improved or not. At best, my butt dyno tells me that the engine is starting to open up and is becoming more consistent in the feedback that it is giving me.
    Right now, my odo only reads 1100kms. Majority of the people I've spoken with tell me that fuel consumption at this point in time should not be something that I need to keep an eye on. I'll give them the benefit of the doubt and will not lose sleep over it until over 5K odo. Right now, I'm doing 8km/L pure city driving, in moderate traffic conditions 70% of the time.
    On knocking:
    I have not heard any knock from the time of my last post. Don't get me wrong, I've worried about it so much that I expect to hear it everytime I drive the car. I'm happy I don't hear it, but just to manage my expectations, I keep in mind that it can still come back.
    I can't confirm the extent of knocking that the other have experienced, but the last I've heard from mine was very, very short - think about a can of evaporated milk with thicker material and a spoon hitting the inside of the can twice in rapid succession. Before, I hear it when the tranny downshifts - usually from third to second or second to first.
    Hope this helps.
    Jun 2012
    #1011
    On Motor oil:
    On knocking:
    Hope this helps.
    Thank u so much for this.. Come to think of it... I hear a knock when it downshifts but i thought.. May bato lng na tumalsik sa car... Something like that... Kaya it didn't bother me.. So i just have to let the service guy update the ecm right?
    I'm hoping that my fuel consumption improve after this...
    Sorry for a lot of questions since this is my first car and i dont know anything about it...
    Apr 2004
    #1012
    Just a word of caution though...
    Don't get caught up in the feeding frenzy. In the same manner that some people may not be complaining about their Accents because they do not know what to look for, there are people who also start hearing things just because they read too much about the problem and its symptoms.
    I know somebody who went ahead and had the ECU upgraded just because he thought he started to hear knocking sounds from his engine. Ayun, inupgrade yung ECU hindi naman pala kumakatok yung makina in the first place...
    If it ain't broken, don't fix it.
    Nov 2007
    #1013
    You hit the nail in the head sir.
    Anyway this is my accent's fuel consumption from the previous full tank fill. 40% City, 60% provincial highway and I travel 34KMS a day...
    Type of fuel? hehehehe, I gas up on almost all brands. TOTAL, PETRON, SHELL, FLYING V. I don't have any issues at all except that I notice na parang mas ok yong consumption ng sasakyan on shell unleaded. However, I am very picky with the gas station na pinupuntahan ko. I always choose the newly built stations, if not, yong mga stations na maraming customer where inventory movement of fuel is fast...
    #1014
    Quote Originally Posted by meikey View Post
    Very good rate of fuel consumption, bro...
    What are with the keyhole, three dots, and car icons on top of the L/100Km icon... What are they for?...
    16.0K:dude:
    Nov 2007
    #1015
    sir *cvt, It's visual representation lang po on "Distance to Empty" aproximation, apart from the main fuel gauge on the rightmost side of the display..
    The day I got my accent, my fuel consumptions plays within that range.. Although I must say a variance of I guess around +5-10% on manual computation ng kilometer run against fuel consumed.
    However, as a proven fact, masyadong mahina ang hyundai pagdating sa underchassis. I've got some weird stuffs happening on my accent, but I am glad that my dealer served me well as I don't have to raise my eyebrows to claim any warranty.
    #1016
    Thanks for the response bro. Interesting icon/s...
    On the Km/L or L/100Km gauge/s,- I guess it is the same for all car manufacturers. I have the same experience with our Honda and Toyota vehicles, too.....
    16.0K:dude:
    Jun 2012
    #1017
    True... Tuloy ngyon super conscious na ko if may maririnig ako or wala... Just a question though.. Since nung binili ko sya..shell unleaded na ung gamit ko... Pero many advised na mag premium ako... Ok lng ba to gas up with premium kahit na may laman pa na unleaded? Like today may 3 bars pa ako.. Pwede na ba ko maglagay ng premium? N eto ba ung shell nitro+?
    #1018
    Pwede mo paghaluin yan.
    Aug 2005
    #1019
    Guys i need your help..
    Where is the alarm module of the accent?
    I cant find it..the alarm is going bezerk and i need to reprogram it...
    Dec 2011
    #1020
    yun ba yung knocking? yung parang may batong tumalsik? i sometimes hear that.
2011 Hyundai Accent issues, problems in general
