Results 41 to 50 of 1710
May 2nd, 2011 10:00 PM #41
Labo naman nito. Entry level car na mapili sa gas?? Kaya nga nagsubcompact kasi matipid sa gas tapos mas mapapagastos ka pa pala sa gas.. If our gas isnt up to spec with the newer engines, e di dapat di nalang nila nilabas dito. They shoulve tested it first. This is their reason before for not introducing ung GDI engines diba? When they release new cars here, it should be given na they will run under local conditions.
I hope isolated case lang ito. If not sayang naman. Ganda pa naman ng Accent. And hope the elantra will be different.
- Mar 2004
- 111
May 2nd, 2011 11:15 PM #42inaabangan ko ang thread na ito kasi i'm also hearing slight engine knock sa tucson theta engine ko since 1k pms. 11k na tinakbo ng engine ko pero nandun pa rin from time to time un tope and maybe nasanay na ako sa sound ng engine. ilan beses na ko nagpabalik balik sa casa but ang lagi lang sinasabi is normal lang daw yun sound ng engine. mismong service manager na nagtestdrive. wala rin makita na abnormal readings sa GDS and lahat ng parameters pasok sa spec.
sana may makita ang casa or HARI na solution for this or claim na engine noise is inherent sa Hyundai engines.
mas ok siguro magcompare ng engine sound side by side para malaman if normal lang din ang noise... or better yun TS magtestdrive ng ibang unit for direct comparison. wala pa lang din ako natestdrive na ibang tucson to check.
May 2nd, 2011 11:27 PM #43
Same thought here Sir, bakit pa inilabas dito ang mga accent kung ang pagbibintangan lang nila ay ang gasolina... PALPAK talaga....
Mas tatangapin kopa kung sasabihin nila na may problema ang makina, which of course they would not do... I hope this are isolated cases and pray that it won't happen on my unit....
May 2nd, 2011 11:37 PM #44
May 2nd, 2011 11:50 PM #45
Tucson naman ngayon????
Ok yun Sir, inherent na knocking sound sa Hyundai engines, baka bagong pa uso ng hyundai, instead of the vrooom vrooom sound eh knocking sound na ngayon sa mga brand new units.
Joke or not, its interesting to know how will Hyundai answer all this, ang kawawa lang talaga ay tayong mga consumers, dahil sa PALPAK na reasoning nila.
Para naring sinabi nila, bawal magpa gas sa petron ha, dahil masisira ang unit mo...........
May 2nd, 2011 11:55 PM #46
May 3rd, 2011 12:04 AM #49
May 3rd, 2011 12:05 AM #50
Tama..
Hindi naman kasi ako kuripot para mag-reklamo sa PMS cost ng CRDi eh. Been there, done that. Worse than that pa :hysterical: Madali nalang maintenance ng CRDi kapag na-experience mo na yung failure ng Isuzu Trooper.
Latest mileage:
