Results 1 to 10 of 14
May 16th, 2007 02:33 AM #1May naputulan nb ng timing belt sa inyo na hindi na kelangan ng top overhaul?
thanks
- Jul 2007
- 88
July 12th, 2007 11:49 PM #2Yes Sir ako po twice na naputulan pero never pa nag-overhaul, basta palit lang ng original na timing belt wla magiging problema.
July 12th, 2007 11:53 PM #3
On a non-interference type engine, you can survive a snapped timing belt without having to open up the engine afterwards.
Around here we already snapped the TB on a Mitsu 4d56 and 4g63 .
- Jul 2007
- 33
July 16th, 2007 12:43 AM #4ako din, naputulan ng timing belt.. bale nagpalit lng kami ng timing belt pati na rin yung mga rocker arm na nasira hindi na inoverhaul makina ko. until now ok pa rin.. my engine 4d56
- Jul 2006
- 37
July 16th, 2007 07:17 AM #5
July 16th, 2007 07:23 AM #6
I'm not so good at explaining this concept. Maybe this can help:
Timing belts are typically inaccessible and difficult to inspect. Replacement at specific intervals is recommended by the manufacturer. The manufacturer may also recommend the replacement of other parts, such as the water pump, when the timing belt is replaced because the additional cost to replace the water pump is negligible compared to the cost of accessing the timing belt. Failure of the timing belt will leave the engine non-functioning. Depending on the design of the engine, the piston and valve paths may "interfere" with one another and incorrect timing in their movements may result in the piston and valves colliding. (Such designs are also called "interference head" or "interference engines". Conversely, non-interfering engines are called "free-wheeling" or "non-interference" engines.)
In interference designs, regular service is especially important as incorrect timing may result in the pistons and valves colliding and causing extensive engine damage and therefore costly repairs. The piston will likely bend the valves or if a piece of valve or piston is broken off within the cylinder, the broken piece will cause severe damage within the cylinder, often also affecting the crankshaft. In some newer engines, timing belts are designed to last the effective life of the engine. When a timing belt is replaced, care must be taken to ensure that the valve and piston movements are correctly synchronized. The usual failure mode of a timing belt is stripped teeth (which leaves a smooth section of belt where the drive cog will slip) rather than an outright snapping of the belt, which is very uncommon. Correct belt tension is critical - too loose and the belt will whip, too tight and it will whine and put excess strain on the bearings of the cogs. In either case belt life will be dramatically shortened. All engines feature an adjustable tensioning roller to allow correct adjustment of belt tension.
- Aug 2007
- 2
August 7th, 2007 01:41 PM #7
January 30th, 2008 12:33 PM #8
Basta pag naputulan ka ng belt wag attempt to start doon masisira kasi malakas ang wear pag nag start ang engine pero pag umaandar tapos naputulan ka ok lang wla masama effect just change it every 80k ang inspect water pump kasi magkatabi un
February 29th, 2008 12:36 AM #10
habang tumatakbo ang sikot mo at biglang na putol timing belt di ba mamamatay ang makina paano mo malalaman na timing belt ang problema at hindi mo na kailangan i attemp restart ang engine. kasi [pag namatayan ka ng makina ang tendency ng driver is to restart the engine.
In my car idle on coldstart was 2k high need 2 to3 mins to be restarted the engine to get the...
high idle RPM at engine start
