Page 2 of 8 FirstFirst 123456 ... LastLast
Results 11 to 20 of 75
    Jan 2011
    Quote Originally Posted by doobeedoo View Post
    pero pahabol na tanong nalang po mga masters, one friend said that the Jazz has 8 spark plugs, and you need to change them every 10K i think. you have an idea how much it'll cost to change those spark plugs?
    thanks!
    Spark plugs can actually last more than 50K, and you don't have to replace it every 10K. But if you'll be comfortable replacing the SPs every 10k, then do it.
    Also, check your manual about Maintenance Minder. Honda cars are equiped with maintenance minder, this will light up when your Oil Life is at 15% and it wil signify a code what maintenance should be performed. (e.g., A1) where A Replace Engine Oil, and 1 signifies Rotate Tires. For B4, it signifies Replace Oil and Oil Filter and all other 9 point ++ inspections and other services. 4 means Replace Spark Plugs.
    Maintenance Minder was put in place so that the voodoo guessing when and what to replace during maintenance will be more accurate, hence will make the vehicle cheaper to maintain.
    Dec 2002
    pms is around 3k+. next week my car is done for dent repair and 20k pms i'll try to post next time for the actual pms cost.
    btw are you getting the new MMC jazz or the old GE model.
    Mar 2011
    Dapat ba talaga papalitan spark plug ng jazz Ko na nasa 10k pa Lang pero 20k pms na Ang tatamaang maintenance? Kase due na Ko until next sat, June na maintenance tinawagan na Ko ng scheduler. Kaso 8500 Ang estimate, kala Ko nasa 4-5k Lang babayaran Ko
    Oct 2011
    Quote Originally Posted by CoachLC View Post
    masyadong maaga for a 10k replacement ang spark plug afaik. not unless may physical evidence na ito ay kailangan ng palitan.
    Mar 2011
    Thanks retz, Hindi naman ba mavoid warranty Kung sabihin kong change oil na Lang muna Medyo wala sa budget eh. 15 months pa Lang jazz Ko at 10k tapos 20k pms na, Eto Ang Gagawin daw,
    Oil filter
    Drain plug washer
    Air cleaner element
    Engine oil
    Spark plug
    Sa Honda magallanes ako Nakasched Di Ko sana trip dun kaso malapit sakin less hassle. Baka pag Sinabi kong wag na muna spark plug takut Takutin ako eh.
    Jan 2012
    Based on personal experience, heres the breakdown of the expenses on PMS i've incurred so far on my 2010 Honda Jazz 1.5V
    6 months or 10K PMS
    Actual ODO Reading: 6,400K
    Service Center: Honda Pampanga
    Details:
    4 Ltrs Honda Fully Synthetic 5w40 - 2,200
    Honda Oil Filter - 322
    Drain Plug Washer - 29
    Labor - 1,120
    Total: 3,671
    1 Year or 20K PMS
    Actual OD Reading: 13,707K
    Service Center: VM David Service Center
    Details:
    Motul Htech 100 Fully Synthetic Oil 10w40 4 Lts - 2,200 (550 per liter)
    Drain plug Washer - 29
    Disk Brake Cleaner - 250
    Labor - 220
    Tip - 50
    Total: 3,071
    Excess oil from the 4 liters was given to me
    1.5 Year or 30K PMS
    Actual OD Reading: 21,074K
    Service Center: TC Tech Service Center
    Details:
    Motul Htech 100 Fully Synthetic Oil 10w40 4 Lts - 2,000
    Honda Oil Filter - 359
    Brake Cleaning - 600
    Tip - 100
    Change oil Labor - 200
    Total: 3,288
    If you do a comparison of the PMS cost of a Jazz and an Avanza or Vios, medyo mas mura toyota but depends on where you get it done. if you have it done sa casa, good luck with the cost kasi sa langis pa lang tatagain ka na sa presyo. what i do with my dad's avanza is that i get oil elsewhere. i have friends who sell per gallon of fully synthetic oil of toyota for a really cheap price and orig toyota oil filter tas we even get to keep the excess oil. like for 1.3 avanza J, 3 liters of oil lang, so dun sa 1 gal may 1 liter pako natitira. so next oil change, 3 liters na lang kailangan namin. laking tipid.
    re: spark plug, dun sa old iDSI engine ng Jazz GD, 8 plugs yun, so magastos nga. pero dun sa GE model, 4 lang, pero iridium plugs ( <> 500 each) pero good for 100K naman so sulit versus regular plugs around 300 each good for 10K, well... thats what i did before with my kia using reg plugs.
    Mar 2011
    Thanks bro, take note Ko to for comparison na din, sa casa kase ako magpapagawa eh, salamat again
    Dec 2004
    Quote Originally Posted by bayen View Post
    6 months or 10K PMS
    Details:
    Labor - 1,120
    Total: 3,671
    1 Year or 20K PMS
    Details:
    Labor - 220
    Tip - 50
    Total: 3,071
    1.5 Year or 30K PMS
    Details:
    Tip - 100
    Total: 3,288
    WOW, did I just get ripped off?? I just put in a 2013 Honda Jazz 1.5V for 1year / 20kms PMS and got charged Php 10.3k at Honda Shaw!
    I know this thread is from 14months ago, but I don't think prices should have inflated that much.
    Is there anything unusual in this breakdown? So that I would know better next time...
    Odo. = 14T kms
    Total = Php 10,342.04
    Breakdown,
    [LABOR] 20km checkup - 1,344.00
    [LABOR] DT Perform Fluid, Battery and #Fan - 198.11
    [LABOR] Testing procedure (Use diagnostics TEST, INSPECT OR DIAGNOSE SIDE SLIP - MEASUREMENT) - 100.80
    [LABOR] PERFORM QUALITY INSPECTION - 0.00
    [LABOR] PERFORM FLUSHING SERVICE ON A/C EVAPORATOR - 504.00
    [LABOR] DN COMPLETE WASHING (engine wash) - 849.98
    [PARTS] X-1R ENGINE TREATMENT 250ML - 995.00
    [PARTS] WASHER DRAIN PLUG 14MM - 28.82
    [PARTS] WINDSHIELD WASHER CONCENTRATE (OWS) - 145.00
    [PARTS] OIL FILTER - 321.17
    [PARTS] WYNN AIRCON KIT - 1,308.16
    [PARTS] MOTOR OIL HONDA FULLY SYNTHETIC 0W20 (D) - 2,420.00
    [PARTS] ELEMENT FILTER CT 09-11 JZ 09-12 - 1,903
    [PARTS] SUPPLIES - 224.00
    Jul 2011
    Quote Originally Posted by ponsoteneo View Post
    Odo. = 14T kms
    Breakdown,
    eto hindi naman talaga kailangan
    eto ba ung air filter ng engine? dapat 20K palitan nyan tapos pwedeng ikaw na magpalit wala pa Php1K yan,
    Dec 2004
    Quote Originally Posted by s10pao View Post
    Yep, this is the 1year/20T kms checkup. The agent told me "[PARTS] ELEMENT FILTER CT 09-11 JZ 09-12 - 1,903" is for the engine.
    For the next checkup, I'll opt-out for those items. Thanks for the inputs. Sana lang they won't counter-attack by voiding the warranty, especially if I do the filter replacements outside the casa.
Honda Jazz Maintenance
