Results 11 to 20 of 23
- Jul 2014
- 162
July 31st, 2014 11:27 PM #11Mga sir dami po pwede pagmulan ng jerking.. Pwede sa engine tulad ng my misfire o kaya problema K. Sensor.. Pero kung 1st gear lng ang jerking pwede sa swicth sol o lock up valve o primary pressure valve.
Tsikot Mobile App
August 1st, 2014 01:57 AM #12
Maybe one of the spark plugs is busted. When was the last time you replaced it?
I may be stupid, but I am not a fool.
- Oct 2010
- 3
- Oct 2009
- 348
September 12th, 2014 09:40 PM #14
- Sep 2014
- 1
September 18th, 2014 07:03 PM #15Hi had the same problem with jazz 2005 Automatic - jerking/choking problem while running. Had it brought to Casa findings was injection coil changed the 2 coils but after some time the jerking/choking came back. Had it checked outside sabi baka daw fuel filter brought it back sa Casa told them about the outside mechanic's reco, they had the fuel filter checked and found it needed changing so baka daw yun ang cause ng jerking dahil madumi na.
Had the fuel filter changed but after a week there is still jerking/choking pero not as strong as before. Since i still had warranty from my recent visit i went back and complained about the persisting problem. Finally they zeroed in on the connecting cables sa spark plug loose na daw wala nang clip because matagal na din yung unit. Sinikipan lang nila yung mga connections so far smooth na takbo haven't experienced the jerking/choking since i got the unit back.
- Oct 2014
- 9
November 14th, 2014 06:16 PM #16Same problem w/ my jazz vtec automatic, di makuha ng casa, dinala ko ke mel alcasaba sabi palitan ng ignition coil pack ayun broooom para na siyang bago.
November 14th, 2014 10:11 PM #17
Aside from the Casa, where else could i reprogram the cvt? I had to replace the battery..
- Jun 2008
- 28
November 21st, 2014 05:08 AM #18Hi Everyone,
Apologies for the late reply, As it is I had the vehicle repaired by Mel Casaba. All in all he found out that it was the solenoid that was defective. He was able to find me new parts and installed it immediately.
Mel's service was excellent, cost was better than I originally planned but still quite high. Either way, Mel was the only one who was able to help me out and give me excellent feedback on my car.
Glad to have learned of Mel's repair shop through Tsikot.
Thank you very much Everyone!
November 21st, 2014 08:35 AM #19
November 21st, 2014 11:10 AM #20
[QUOTE=blastme33;2428047]Hi Everyone,
Thank you very much Everyone![/QUOTE/]
Ano po exact address Ni Mang Mel Canada at cellphone number???
Somewhat expected from a rushed car from a first time carmaker
Xiaomi E-Car
