Nice information. Try ko later. Thanks!
Sir ask q lng po newbie s honda car kse mali dw po nailagay q na atf oil shell apirax po oil na nirecommend ng mekaniko nmin pero as per may tropa dpt dw pg honda mas mgnda dw atf Z1 or cvtf dw dpt oil n ilagay q a transmission. Worried lng aq bka masira ung transmission q sa nilgy q na oil. Pero balak q drain at palitan agd dis week ung atf oil ng cvtf or atf z1 ng honda. Ok lng po ba yun sir nalagyn q ng maling oil.tnx
Kung Honda CVT transmission ng sasakyan mo recommended, from any site, is to use authentic Honda CVTF, as this version of Honda CVT is sensitive. Don't risk it to avoid expensive CVT failure wherein you will need to have it replaced to fix. This is for Honda City and Jazz CVT.
Pero kung standard transmission lang ok naman yata kahit third party ATF.
Change asap.
Lots of damaged cvt because of stupid mechanics using regular atf fluid.
Owners manual includes which fluids to use. Owners should read it. Hence owners manual.
Cvt oil change interval nasa manual also. Every 20k?
Pag kakachange mo lng after 75k.. of course meron na possible damage.
Uy! mukhang may bagong member kami sa group. Welcome sir! PM mo lang ako pag need mo replace tranny mo ha. He,he.
Drain it ASAP and change the fluid. Use only recommended CVT Fluid by Honda. If wala ka pa budget pangpalit CVT, wag mo muna gamitin auto mo or even start the ignition. Malaki laking sakit ng ulo ang naghihintay sayo pag nagkataon.
Sir maraming salamat po ahhh.. s advice. Salamat din po s wc. Oo nga sir palitan q agd kakatakot mas malaking gastos pgnagkataon. Tnx ulit.
Sir last question po sir ung po bang gearbox oil un po ba ung cvt na oil? Honda jazz vtec 2006 model A.T po pla sskyn q.
Hindi ako sure kung CVT na yung unit mo pero kung nakalagay sa manual mo CVT Fluid and dapat gamitin sundin mo na lang. Ang alam ko kasi naglabas na honda ng mga bagong A/T na hindi na katulad nung palyado na CVT.
Sir natanong q n po cvt nga po tranny q sor may ma irecommend po b kyo na blihan ng cvtf fluid? At ung genuine po. Salamat po
Sir need your expert opinion pinayos ko na po yung sa transmission ko nagpa bleed na po ko bali 2 beses na po drain kase nahaluan nga po ng atf fluid kaso bakit ganun po cvtf na po nakalagay ngayon kaso parang iba na pakiramdam while driving parang may suntok na ewan or parang may mararamdaman ka ano po kaya yun? Nasira na po kaya transmission ko? Parang mas ok pa takbo nung may halong atf kesa sa ngayon. Salamat po
