hi guys. question naman dun sa known CVT problem ng city. anong mga models affected nito? kasama ba city 07 and 08? thanks!!!
ilan percent ang chances na magkakaron ng gantong problem ang honda city? bibili kasi kami 2nd hand honda city 2008 model. and nabasa ko to. sobrang worried tuloy ako na baka hindi din magtagal yung auto. help guys! thanks!
heard stories of the then brand new city (not the current releass) whose cvt had weird noises a few months after it was bought...
yung 7speed AT na matched sa idsi engine ang may problema...
Sent from my Thrill 430x using Tapatalk 2
Matrabaho pala CVT ng mga honda, need pa magpareset ng CVT everytime magpapalit ng batery.
sir nag palit ak ng battery a few months ako kasi na ded batt nko pero hindi ako nag reset ng cvt kasi nideliver lang yung battery sa haws namin.. should i worry about this? pansin ko rin a few weeks na kumakadyot minsan yung jazz ko.. cvt issue kaya yun? hindi parin kasi ako nag papalit ng cvtf eh.
Mga sir Hindi po kailangan ireset ang ang TCM kung tatanggalin lang battery.. Pag tinanggal nyo nga ang battery automatic reset na iyon kung my mga DTC na nkastored sa ECM o PCM
Tsikot Mobile App
Mga sir question lang, ung 2013 honda jazz 1.5v, CVT din ba un? or regular automatic lang xia?
Bro i-VTEC has NOTHING to do with the type of transmission your City/Jazz has.
i-VTEC is your engine's variable valve timing system. It stands for Intelligent Variable VALVE TIMING and lift Electronic Control.
Regardless of whether your City has iDSI, VTEC, or iVTEC, it can have a CVT or conventional AT.
The Cities/Jazzes that were released locally with CVTs were the 2003-2008 models (GD body code).
The next generation (GE Jazz, GM City) had conventional 5 speed torque converter automatics.
The current generation (2014 onwards) has returned to using a better version of Honda's CVT.
Posted via Tsikot Mobile App
guys need some inputs I have Honda 2008 idsi, im wondering why my plugs always busted around 10,000km, 1st I do replace all 8 plugs at the same time, then I exp. after 10k mileage jerking starts and ill just replace 4 plugs then jerking gone....after 10k mileage again or 2 months again problem start until now this is my problem...when I check the plugs no oil, burning is good....I this really normal or my car have problem?
check wires and casing.. bka may mga crack na. happened to me before.. after tune up after a few days nag jerk ng malakas oto.. my tito mekanik checke the sparks.. noticed that some casing has cracks.. after putting some tape to secure then nawala yung jerkiness.
Mga sir sorry if OT.
I am about to buy 2008 idsi CVT. 80k+ milleage for 240k.
Ni road test ko sya. nag tataka lang ako pag nag switch ako sa S mode nag chachange gear din sya ng kusa in less 4k rpm. Di ko pa na hihit ung + button. Same din po ba sa inyo?
Pa explain further naman po ung S mode. Ang alam ko kasi it will work like manual tranny pero di ganun nangyari sa road test ko.
2nd is ung blower ng AC di kasing lakas ng blower ng ibang oto. Normal ba un sa ganitong model?
3rd is..pag nag S mode ba need pa i press ung 7 speed sa steering wheel?
Pa explain po
Thanks in advance!
