Results 11 to 20 of 81
- Aug 2013
- 805
July 18th, 2014 08:02 AM #11Kung CVT ang transmission malamang iyan yung CVT issue ng City at Jazz model. Palit ng transmission ang permanent fix. Google search nyo Honda CVT problem.
Posted via Tsikot Mobile App
- May 2014
- 1,318
July 18th, 2014 01:12 PM #12Most likely it is a transmission issue. We own 1.3 i-dsi same generation Year 2008 before the model change.
Our jerking was still just present when slowing to a crawl and accelerating from idle. Well jerking or shuddering. In our case, we only had to replace the ATF and had the flywheel replaced and after Honda did it, okay na siya.
Better have your transmission checked. Hopefully it is just the flywheel and ATF replacement to fix the problem. But if not, it might be the transmission na.
Damage sa akin was total about 22k sa Honda casa to have everything done. 15k for the flywheel, around 2-3k for the ATF fluid. Plus pa yung PMS na 5k. FYI.
- Jul 2014
- 162
- Jan 2011
- 109
- May 2014
- 1,318
July 18th, 2014 03:22 PM #15I am not knowledgeable whether the City has a torque converter but yes, flywheel and ATF lang nakuha na.
Two years ago naman lumabas yung grinding sound sa rear wheels ng kotse. Pinalitan yung rear wheel bearings, nawala din naman after nung pinagawa yun, can't remember the total cost to replace.
Regarding the transmission, I checked forums in Malaysia as well and noted sa kanila that if the City is mainly Asian City urban traffic used mostly, dapat every year or 20,000kms palitan na daw CVTF ng City just to be sure. Original schedule supposed to be every 60k kms. Wala naman personally na advice sa akin Honda na next year papalitan ulit ATF kasi early this year lang nagawa yun. I didn't bother to ask.
Pero If require nila sa akin next year, papapalitan ko na lang din CVTF to be on the safe side kaysa masira transmission ko. Maganda pa naman takbo after naayos, may mga onting sumpung lang. Never ako nag manual mode except to try it less than 10 times for its whole life.
- Jul 2014
- 162
July 18th, 2014 03:41 PM #16Sir meron na ba sa atin ngayon na automatic transmission rebuilder? Asean, American, European
Tsikot Mobile App
- Jul 2014
- 3
July 24th, 2014 01:54 AM #17hi guys. question naman dun sa known CVT problem ng city. anong mga models affected nito? kasama ba city 07 and 08? thanks!!!
November 7th, 2014 07:04 AM #18
- Feb 2010
- 1
June 6th, 2017 03:57 PM #20yup i experience this last month jerking and shuddering on my honda jazz 1.3 AT , final verdict palit tranny , huhu ...
the triumph of man over... man!, using the crudest of implements (by modern standards).
Traffic!
