Results 71 to 80 of 82
October 16th, 2014 02:54 AM #71
October 29th, 2014 02:02 AM #72
- Jun 2014
- 2
October 31st, 2014 09:37 AM #73Sa mga Amaze A/T owners ano average FC nyo?
Honda Amaze S A/T unit ko, average FC ko light traffic (6am wekdays Via EDSA) ay nasa 10-11km/L pero kapag medium to heavy traffic (5pm via EDSA) ay nasa 8-9km/L.
kanina 6am via EDSA pumalo ako ng 13km/L (ngayon ko lang sinubukan > naka neutral kapag pababa ng flyover at minsan kahit patag basta nag-gain ako na ng momentum then alaly na lang sa brake) pero baka tsamba lang ito hehehe.
25km ang byahe ko valenzuela to makati via EDSA
- Sep 2013
- 893
- Aug 2006
- 52
October 31st, 2014 10:57 PM #75slipping it in N while moving is quite dangerous
di yan katulad ng old cars na carburator type fuel system it would gain you nothing
- Jun 2014
- 2
November 1st, 2014 09:39 PM #76Thanks For the information, i did a little research and from what I've read you will not save gas putting most automatic transmission cars in neutral, since most cars use fuel injection and are set to dispense the same amount of fuel at idle regardless of being in Neutral. Also, switching in & out of gear while moving might stress the mechanicals... Not a good idea. kaya mga sirs wag tutularan
November 2nd, 2014 10:07 AM #77
Neutral coasting works. Sometimes, preserving momentum is more important than getting exactly 0 liters of consumption per kilometer... because you'll need to spend more fuel getting that speed back.
How stressful it is for the car depends. On most modern automatics, it should not be a big problem. It should be noted that there are automatic transmission cars nowadays that shift themselves into neutral when you lift off the pedal... to save gas. ;)
- Jan 2015
- 6
January 29th, 2015 05:00 PM #78not sure if wala lang masyado feedback on the Brio since it's new. but reviews in TPG and autoindustriya seem generally positive right? planning to test drive one this weekend.
January 29th, 2015 06:07 PM #79
October 4th, 2015 10:46 PM #80
My sister just got a Brio V a/t last week. mas power full kaysa sa Mirage gls CVT. Pero mukang mas matipid ang Mirage and mas maluwag.
Dahil hindi CVT ang Brio, ramdam ko ang mga up-shift nya.
Try ko sa SLEX tomorrow. Santa Rosa to Calamba and back in the evening.
- - - - - - - - - - - - - - - - - - - - - -Last edited by meledson; October 4th, 2015 at 10:49 PM.
Monk-owned R53
