Results 1 to 6 of 6
August 31st, 2014 09:13 AM #1
Mga ts,
Need your advise , when i open/close my car door i hear a squeaking noise.
Car : honda civic 1997 vti
Question:
1. What do u think i need to replace or fix? As per my friend i need to replace hinge... Where can i buy hinge? In surplus only??
Thanks!
Posted via Tsikot Mobile Ap
August 31st, 2014 12:22 PM #3
Door hinges, trunk lid hinges, fuel filler door and the hood hinges are supposed to be lubricated. The most recommended lube is motor oil. I have used petroleum jelly or Vaseline regularly. The Vaseline penetrates the crevices(no pun intended) of the hinges and is not unsightly compared to wheel bearing grease.
Posted through phlpost.gov.ph
August 31st, 2014 12:28 PM #4
WD40 dries up in a matter of days. It's a penetrant and a temp lube at most.
I personally use motorcycle chain lube. I have a can of the stuff from back when I was still riding a bike. It's a penetrant like the WD40, but the lubricant component is a lot more dense and lasts for years.
August 31st, 2014 12:35 PM #5
Meron nabibili sa true value silicon grease yata, basta color white.
Posted via Tsikot Mobile App
Xiaomi E-Car
