Results 1 to 10 of 16
March 31st, 2008 06:14 PM #1
mga sirs,
i am currently driving a civic 98 vti and am looking for a 99-00 model (i'll be driving this one, my younger bro gets my car). puro lxi nakikita ko na year 99-00. just want to ask what are the differences between the vti and lxi for that year.
di ko kasi mahanap yung thread, kung meron mang existing. thanks.
eto lang alam ko:
vti has a 1.6L engine with vtec, while lxi 1.5L without vtec.
March 31st, 2008 09:35 PM #2
manual ung side mirrors
manual antenna
silver/aluminum ung window garnish
yan lang naalala ko eh. hintay natin reply ng iba
April 2nd, 2008 05:12 AM #3
add ko na din nasa vti the central lock ay malapit sa door handle.
also, the trims are different sa vti seats and the side molding than the lxi. then the vti has the arm rest while the lxi does not.
then sa vti yung vtec na 1.6, vtec opens sa 2500 rpm.
April 2nd, 2008 06:03 AM #4
Basing on my current gas consumption both 99 model
Vti eats up alot of gas compared to LXI.
April 2nd, 2008 07:22 AM #5
nasabi na halos lahat, hehe
LXi nasa roof yung radio antennae. black plastic side moulds and rear license plate holder (m/t versions), 13 size alloys. pagbukas mo ng hood plain matte aluminum yung rocker cover, intake swirl chamber nasa ilalim ng airbox.
it's true na medyo mataas ang FC ng vti vs. lxi sa city driving with hataw sa stoplights. pero at highway, mas matipid ang vti. at higher speeds the vti uses lesser RPM kasi. i don't know if this is a function of the extra displacement, the vtec mechanism, or gearing, though.
- Apr 2008
- 6
April 6th, 2008 05:50 AM #6mga kuya i used to lower my honda before pro putol lang so wala akong knowledge bout lowering spring height....
anu ba ang pgkakaiba ng mga height ng lowering spring? i mean whats the diffrence between a drop of 1.75" or a drop of 1.5inch or a drop of 1.2 inch? sana matulungan nyo ako i wanna know ilang fingers ang pagitan from the tire to the fender literally.....prefer ko sana ung totally bagsak ang auto ko dhil makati naman ako nakatira...pls sana bigyan nyo ako ng advise
- Apr 2008
- 6
April 6th, 2008 05:51 AM #7mga kuya i used to lower my car before pro putol lang so wala akong knowledge bout lowering spring height....
- Apr 2008
- 6
April 6th, 2008 05:52 AM #8mga kuya i used to lower my car before pro putol lang so wala akong knowledge bout lowering spring height....
mga kuya pa pm na lang ako po...
April 6th, 2008 07:47 AM #9
bro i think this is the link you are looking for;
http://tsikot.yehey.com/forums/showthread.php?t=35120
April 6th, 2008 11:09 AM #10
sir the drop means that kung gaano kababa kesa sa normal height. kung 1.75 that means 1.75 inches lower than stock height.
sa tanong niyo sir parang ang hanap niyo "fender gap" usually fingers na pang gauge diyan... i believe what you want is a 0 gap, kung ganon, take off those stock springs na cut and get yourself coilovers.
parang OT na to... meron thread about this... konteng hanap lang sir.
