1400 php medyo mahal casa kc expected kn un..per hora kc rate pero ok na auto ko dna bmalik problem after nun.. my mga wiring na pinalitan at binago.. k mel casaba ok din ngkataon lng na hindi sya specialized sa electrical thing.. at di available electrician nya.. kung gs2 mo din try honda cavite hanapin mo c lester bubon sbhin mo lng refer kta tyrone name ko civic05 pre hinde ka icha charge ng malaki nun basta mg usap nlng kau..
galing na din ako dyan sor k rafael bautista,, di naman nya na trace main problem nito,, pero pna check kn din com box ko at ok din naman un nga lng di nya na locate electrical lng pla problema.. guyz balik nko states sa monday for work 8months then back pinas,, pls update nyo lng ako sa mga latest trend ng honda here in pinas.. keep in touch guyz.. thankz..
I got a TXT message, from Mel Casaba daw and nasa Sucat na daw yung shop nya? Can anyone confirm this?
OK to para sa akin kung totoo, mas malapit sa bahay.
Andun na nga sya. Sa Sucat road, katabi ng BDO and tapat ng Clarmen Village. Balik ako dun sa sabado to get my timing belt re adjusted.
So I had my Accord tuned by Mel yesterday, had the Throttle body and EACV cleaned, timing belts set "properly", valve tappet clearance adjusted, and the ignition timing adjusted to the 16deg proper spec. After that, nawala na yung hesitation when shifting from 1st to 2nd gear. - which numerous other good mechanics told me na palit transmission na daw and issue dun ... mga olats.
All I can say about Mel Casaba is, he does things by the Text Book numbers. (I know a bit from reading a F22 service manual, since in the past I didn't trust any mechanic)
I am impressed and relieved that I have finally found a competent Honda mechanic.
Mel will definitely be my first option.
Also sinabay ko na din yung power steering pump overhaul.
Boss magkano inabot na charge nitong Tune up mo?? Hope to hear from you!![]()
Hello po sa inyong lahat.... ask ko lang po sana kung patuloy pa ba pong bukas ang shop ni sir Mel sa dasma cavite? or tuluyan nya na po etong isinara? maraming salamat po sa magrereply....
by the way po... meron po ba kayong contact number ni sir Mel casaba? landline or celfone number? salamat po ulit...
Bro, hindi din ako familiar sa Sucat, hinanap ko lang talaga. Kung galing ako ng SLEX, mga 4KM pa sya, malapit sya sa Evacom, side sya ng papuntang SLEX. Kung naka abot ka na ng SM Sucat, lagpas ka na ng 1KM.
ANJ Tire supply yung name ng shop, maliit lang. pero sabi ni Mel meron pa daw silang isang shop na mas malaki, inaayos pa nung nag punta ako.
