Questions About ph15 engine
hi guys and Honda experts, may mga tanong lang po sana ako about ph15 engine. carb type po ba sya or may efi version din xa? sa anong model po na civic nakalagay ang mga engines na to? and if ever may carb type sya, pwede po ba xa i-convert into an EFI?as in papalitan lang ung intake manifold pati throttle nya? thanks in advance, hope to hear from you soon.
Re: Questions About ph15 engine
The one in my old SX8 City was fuel-injected. Not sure if there was ever a carbureted version.
You'll probably have to swap out ECUs also if you're planning on changing fuel systems...the ECU controls fuelling and it's programmed into it (hence the old Honda acronym PGM-FI).
By the way bawal ang text speak
ang alam ko lang na may ph15 carb yung sa mga lumang civic (1991-1993). pero marami ding civic of this generation na naka ph15 efi na din (1993-1995 ESi).
you can convert a carbed ph15 to efi but medyo mahal. the difference in fuel economy won't be that great too. parang ganun din, tipid lang ng bahagya. so hindi mo na mababawi ginastos mo sa conversion.
