Results 1 to 13 of 13
    May 2012
    hello to all, pls help.... yung jazz ko kc nwawala ang lamig ng aircon pag matagal na drive, mga 1hr. lakas naman ng aircon s simula ng paggamit, pero pag matagal na, biglang nwawala lamig. Pag turn off ko engine, rest ng mga 5 mins lumalamig uli. ano kya problema. thanks
    Feb 2003
    Quote Originally Posted by Bryan Garcia View Post
    ganyan din sira ng 2003 honda city ko few months back, nawawala lamig and parang fan na lang pag mga 1 hour na, then pag off mo and on ulit lalamig nanaman .... im 99% sure its the "compressor coil" medyo bilog ang shape ngeto na connected sa evaporator mo. i think it cost a little less than 10k yata pero after changing that, ndi na mawawala lamig ng aircon mo. had mine diagnosed and fixed sa honda cars manila ... lang hiyang SA yan yung una sabi baka cleaning lang daw, but after cleaning , same result nawawala pa din lamig, so yung 2nd time na pinainvestigate ko, nakita na sa compressor coil ang sira and after changing it ok na up to now
    May 2012
    salamat ng madami. mdali lang b pagpapalit ng compresor coil? ok lang kaya na di s honda ko papalitan?
    Feb 2003
    Hmm not sure lang if mabilis magpapalit pero im thinking baka half day job ito since ibababa pa yata bumper just to get access sa compressor coil and yes you can have it changed sa iba . Maliit lang yung compressor coil its i size of a ordinary single horn ng kotse
    Baka madumi na, huwagmo muna papalitan, check mo rin relay...Ibig sabihin niyan nag high pressure...,
    May 2012
    s honda ko naman ko ngppservice, siguro di nman madumi, last n visit ko s honda 7mos ago in good condition nman daw car ko, wala lang ko time pra pumunta ng honda, sunday lang ko may time, ky lang close nman honda.
    Jul 2012
    mga sir ask ko lang san po ba pwede pa check yung honda jazz ko na 2005? nabili kasi namin sya second hand. although may kakilala kami na nag check at sabi ok naman, i was thinking na ipacheck sa honda mismo.. taga laguna po ako. meron po bang malapit dito and magkano po aabutin ng pag pacheckup? btw, naidaan ko siya sa lubak at mejo hindi maganda yung nangyari kasi nagasgasan pati chin.. na paparanoid tuloy me baka may ngyari sa car kasi parang kumakabig sa kanan.. pero ewan ko baka paranoid lang ako... please help po. thanks!
    Jan 2012
    Quote Originally Posted by mk View Post
    actually sir tama lang po yung ginawa ng SA sa aircon niyo...kasi yun ang first step talaga na ginagawa nila if ever aircon ang problem ng auto.. baka cleaning lang ang problema..talaga pong huling tinitignan ang compressor(or any compressor parts)..kasi po mahal ang compressor kaya talagang hinahanap nila ang problem..so kung hindi nila makita ang problem eh pinaka last po ang compressor sa titignan nila. yun lang po salamat.
    Aug 2012
    interim solution lang ba kung relay? me nagsabi pa nga sakin buong compressor need na palitan eh...
    Dec 2007
    The rule of fixing anything is to begin with the cheapest, easiest fix. In terms of A/C systems the easiest fix is to clean out the refrigerant lines.
    You wouldn't be cussing the SA had he/she told you your A/C compressor was shot and had you known how much a replacement A/C compressor for GD Jazzes and Cities costs. It is NOT cheap. The entire compressor is PhP26,000 as quoted two years ago by Honda Quezon Avenue, and I've heard other dealerships quoting me twice that price for the same part.
    Jun 2008
    my take on this is: Kung pawala wala ang lamig, first thing to check is kung ang compressor ba ay tuloy ang ikot kapag ang temperature sa loob ng kotse ay di pa malamig/abot ang setting. kung tuloy ang ikot so ok ang magnetic clutch (compressor coil ang sabi nyo sa itaas). Kung tuloy tuloy naman eh dapat check kung nag ice (frosted) ang return line to compressor. Kung yelo yan, siempre ang evaporator coil yelo rin kaya di makadaan ang hangin so mainit ang buga, pag pinatay ang compressor after a while matutunaw ang yelo so pag andar ulit lalamig na naman kc mag passing through naman ang hangin.. ito muna ang icheck. bugok ang SA kung jump agad sa cleaning di pa na diagnose na maige.
    Dec 2007
    sir this is exactly the problem of my jazz gd... may i know kung ano ang ginawa at nangyari after madala sa casa?
    Dec 2007
    finally had my jazz fix at nakita uli aircon mechanic in fairview from caloocan... grabe dun sa mga known aircon shops (wont name names) kung ano2x ang mga sinasabi palit compressor, evap, condenser, etc.. yun pala magnetic clutch coil lang.. ayun lumalamig na uli pag engage ng thermostat.
2005 honda jazz aircon problem
