Results 11 to 18 of 18
July 26th, 2011 09:05 PM #11
may be to save fuel, syempre nga naman, the higher the gear you use the fuel efficient it is. 2nd gear ako kapag nagha-humps (syempre nakabuwelo na rin naman e) saka pagnaahon 2nd gear kaya nadun sa besta namin, pero pagtraffic like stop and go or then biglang abante o arangkada, 1st gear,
July 29th, 2011 04:28 PM #12
Starting on second gear wont save fuel if you're coming from a standstill. You may even waste more as you'll have the propensity to push the gas pedal more to get moving since the engine is having a hard time.
Best to start normally from 1st gear and only use second in instances such as when you have some momentum or you're on a downhill grade.
- 52,731
July 29th, 2011 05:32 PM #13the traditional practice is to use first gear when starting from stop. there's really no significant advantage or disadvantage in using second gear from stop, just as long as your engine can take it. and most diesel engines can take it.. but there is the safety factor: using second gear from stop does give the vehicle a faster speed sooner.. not to mention the comfort factor..
July 29th, 2011 05:37 PM #14
July 31st, 2011 05:09 PM #15
buti pa si vinj na gets yung sinasabi ko,
I mean on the start up, usually 1st and 2nd gear, alanganin naman mag 5th gear sa simula pa lang, bagito moves naman yun,
Dr.D has a point, starting on 2nd gear is a quick move, it gives a faster speed sooner nga,
- Jun 2009
- 837
July 31st, 2011 05:28 PM #16the first gear was invented for a reason. use it kasi otherwise sana segunda na lang lagi ang start ng mga kambiyo sa mundo diba hehe but then again if that happened we might have a thread entitled: "start on the 3rd gear.."
- Apr 2011
- 408
August 6th, 2011 01:27 PM #17Ako minsan nagsstart sa 2nd gear sa diesel engines pag tinatamad magdrive kasi kaya na sa 2nd gear malakas na ung hatak parang 1st gear narin eh.
- Aug 2011
- 166
September 28th, 2011 10:08 PM #181st gear always unless nasa motion na ang sasakyan (like in a downhill).
high idle RPM at engine start
