Results 11 to 20 of 25
July 25th, 2011 05:30 PM #11
I meant the pampasaherong jeep. My ex mentioned before wala daw handbrake yun. Naisip ko nga how do they park pag inclined area. I took his word for it na lang. hehehe.
July 25th, 2011 05:32 PM #12
Yes, I have done it. It takes a bit of practice to get the timing right with the gas pedal and shifter. And you can only do it when you are on the move, minimal traffic helps.
But even with the best timing, you will crunch the gears which will lead to premature wear & tear. Each time you "crunch" the gears, it shaves off some metal filings into the gear oil. Do it often enough and your gear oil will be more metal than lubricant.
Just save this for emergency driving when your clutch pedal has failed or similar.
July 26th, 2011 12:24 AM #13
July 26th, 2011 01:02 PM #14
Second this. While it's possible to time it so that you won't get a gear crunch, you will still grind them from time to time... so they'll wear down.
On old-school rear-wheel drive diesels, the gear cogs are big and durable, so it's easy to do this... hell... the older the gearbox, the easier, as the edges of the teeth wear down over time. But with modern, compact five or six speed front-drive boxes in sedans and hatchbacks, the chances of stripping gear or synchro teeth are much higher.
July 26th, 2011 03:38 PM #15
oo magaling nga siya madam Cathy, gusto ko rin mag-practice para gumaling ng ganun, hehehe!!! grabe, katabi ko yung jeepney driver na yun, then pinanood ko yung driving style niya napapatulala ako nung nag-shift na siya ng gear, saka grabe kahit clutchless ang smooth ng transition ng gears niya.
and also about what you mentioned oo, restricted nga ang windshield ng jeepneys, kaya minsan mahirap makita yung ang traffic light na nakamount sa taas.
so GH, kailangan din ng tamang RPM? I have doubt to try kasi nga baka ma-grind ko lang,
may mga instances kasi, like kapag nagddrive ako ng corolla, kapag hindi sagad sa floor yung apak ko ng clutch e parang may naririning nga akong nasabit/ weak sounds of grinding gears, may be susubukan ko muna sa multicab, nakakatakot kapag sinubukan ko sa kotse talaga e,
and also my friend mentioned when I asked him what clutchless shifting is all about, He says that it is also a lost art in driving.
yah, Niky you're right, at first I thought that jeep was using a dog clutch pero napansin parang hindi e, kasi nagamit din siya ng clucth pag1st gear saka mag-ddown shifts, clutchless lang pagmag-uup shift, I think that jeep was some of the first models release by lawin motors pa, luma nga yung jeep na nasakyan ko, but the transmission what the f*!!!, it was so amazing. So, now I get the special ability of the old-school trannies.
July 26th, 2011 04:44 PM #16
Kinda. When you shift from one gear to the next gear, you have to match engine RPM with the current speed of the tranny. It also helps to momentarily unload the engine when doing it so you dont loose too much speed or momentum.
July 26th, 2011 05:20 PM #17
What's the point of doing this? Your car has a clutch system then better use it.
July 26th, 2011 08:26 PM #19
Great to learn for racing, because if you can rev-match well enough to do a clutchless shift, you can shift faster even with a clutch... as you:
1. Won't have to wait for engine speed and wheel speed to match after shifting.
2. Won't experience shift-shock when shifting mid-corner, which means you won't upset the car's balance and potentially cause a spin.
3. Won't wear down the clutch as quickly.
July 27th, 2011 12:24 PM #20
