Results 191 to 200 of 386
July 25th, 2014 11:13 PM #191
It shifts faster than a regular automatic that's for sure... I did not notice any improvement in fuel economy naman compared to standard automatics and manual...
*Ry_Tower
Kakatakot naman yan. 4X na pinalitan? Pag ako sa kakilala mo matagal ko na binenta yan. Sakit lang yan sa ulo, 4X within the warranty period is insane. Smells like a lemon hehe...
July 25th, 2014 11:33 PM #192
If it shift faster than a regular automatic, would it be an advantage in your everyday driving? Or it is suited more for racing?
Posted via Tsikot Mobile App
July 26th, 2014 12:36 AM #193
I had my Fiesta Ecoboost for a week already but I have not experienced any bad jerking in low crawling traffic. I do feel the shifting from 1st to 2nd gear but no shakes or jerks. It's fun to drive in Skyway or SLEX as it can easily get up to speed. The torque at low speed is very much appreciated.
- May 2006
- 1,668
July 26th, 2014 02:18 AM #194A good read explaining DCT issues.
Dual-clutch transmissions: dry clutch on the way out?
Basically, GetRag is phasing out dry clutch transmissions and heat is the enemy of dry clutch DCTs.
Currently Fiesta and Focus has dry clutch. Dry clutch can't soak up heat from stop and go traffic, with clutches rubbing against each other + small engine bays with less air circulating, hence they fail. Wet Clutch has heat tolerance built in thanks to the oil bath.
Another thing with Dry clutch, it can't tolerate heat generated w/ clutches rubbing against each other for a long time. ie Big SUVs with small engines, accelerating.
According to Getrag CTO Didier Lexa in an interview with DrivelineNEWS.com, these small engines and dry clutch gearboxes are often coupled with relatively heavy vehicles. When a small engine accelerates a large mass, the gearbox needs a longer synchronising time, which generates more heat. And even when installed in small vehicles, the thermal constraints on these small cars (which have smaller engine bays) are even greater than on C-segment or D-segment cars.
So keep in mind, when using cars with these transmissions, wag ma-stuck in stop and go traffic most of the time. Pedal to the metal maybe twice a month at SLEX.
July 26th, 2014 06:52 AM #195
July 26th, 2014 07:34 AM #196
Just curious. How do you exactly know if you have dry or wet dct?
July 26th, 2014 10:29 AM #197
- May 2006
- 1,668
- Nov 2005
- 1,078
July 26th, 2014 02:21 PM #199
July 26th, 2014 02:43 PM #200
I would not mind bringing a car to the highway for some spirited driving once in a while. Just flooring it on the straights and making sure it can get up to triple digits with no problems. For folks like us from the southern part of the metro, it's good that SLEX/Skyway is part of our daily route but we just have to bear with the daily toll cost.
