Results 5,981 to 5,990 of 7178
- Aug 2007
- 49
- Aug 2007
- 49
April 23rd, 2014 02:09 PM #5982
April 23rd, 2014 03:48 PM #5983
How much did Ford save by not including glove box and tailgate locks sa 2.2 WT? May mabibili kaya na tailgate lock sa casa? gusto ko palitan yung sa akin.
- Dec 2010
- 336
April 23rd, 2014 04:52 PM #5984chips are an easy modification to shift more torque and power to lower rev ranges ... (don't expect to get more power and a lower fuel consumption at the same time as some vendors want to make you believe...) consider, that every time you ask for more power there will be higher wear and tear, on engine and drive train components, brakes and tires - that's the physics ...some chip vendor will give a "warranty" wrt engine and drive train damage: they can do this because they still operate the engine in the same performance range designed by manufacturer via the engine map, but closer to the max. threshold.
Additionally be also aware that more power means more heat the cooling system of the engine has to cope with. While I still believe that most of the overheating issues are caused by lack of coolant in the system a few cases might be also caused by tuning chips: owners are happy about the higher torque when pulling their vehicle up a steep hill ignoring at the same time that the additional heat needs to be exchanged via the same, unmodified cooling system...
- Dec 2010
- 336
April 23rd, 2014 05:09 PM #5985chips are an easy modification to shift more torque and power to lower rev ranges ... (don't expect to get more power and a lower fuel consumption at the same time as some vendors want to make you believe...) consider, that every time you ask for more power there will be higher wear and tear, on engine and drive train components, brakes and tires - that's the physics ...some chip vendor will give a "warranty" wrt engine and drive train damage: they can do this because they still operate the engine in the same performance range designed by manufacturer via the engine map, but closer to the max. threshold.
- Feb 2011
- 54
April 23rd, 2014 05:21 PM #5986
April 23rd, 2014 06:08 PM #5987
I'd rather my car have a shorter lifespan with more fun than keep it for decades, perpetually short of low-end grunt.
As long as the car lasts a good 5-10 years with minor mods, I'll be happy. Would you have experience of chipped diesels conking out prematurely?
Posted via Tsikot Mobile App
- Aug 2007
- 49
April 23rd, 2014 08:35 PM #5988
April 23rd, 2014 09:16 PM #5990
Traffic!
