Results 4,581 to 4,590 of 7178
- Nov 2010
- 369
August 19th, 2013 01:35 PM #4581
- Oct 2008
- 259
August 19th, 2013 01:58 PM #4582very satisfied sa xlt m/t..................san kaya may available na 3.2 wildtrak chili orange
.. sana explorer kukunin namin ngayon ready to pick up na kaso nag bago isip namin reg. sa FC:smiley:
- Oct 2012
- 118
August 19th, 2013 09:47 PM #4583
- Dec 2010
- 336
August 19th, 2013 10:08 PM #4584Recently Ford Thailand called me to conduct feedback regarding my last PMS service done * Ford Cdo. Next day Ford Cdo wanted some explanation from me regarding the comments I reported to Ford Thailand. Hope to see changes to their (SOP)usual services.
Sent from my X909 using Tapatalk 4 Beta
- Oct 2012
- 118
August 20th, 2013 07:30 AM #4585http://farm8.staticflickr.com/7366/9...3d127d5c_o.jpg
Braving through the flooded Espana. Good to have 800mm wading depth. Crosswind conked out here. While Nissan safari patrol was racing through the flood.
August 20th, 2013 09:50 AM #4587
August 20th, 2013 12:22 PM #4588
Mga sir, i am curios and confused when to use 4H.
Sabi sa site na ito When To Use 4WD Off Road - What Does 4WD Mean - Types of Four Wheel Drive Systems
Hi Range 4WD
4H allows you to drive full speed, if necessary. The high range ratios in 4WD mode are the same as the gear ratios in 2WD.
When to use 4H:
for traction when the area isn't steep
when stuck in sand
extremely slippery conditions
snow
ice
rocky, gravel roads
gullies
extremely muddy areas
ridges
Low Range 4WD
4L is for creeping along at slow speeds. It reduces the strain on your vehicle, just remember to stay below 25mph in low range. While it does not provide more traction, it does provide 2-3 times more torque at about 1/2 or 1/3 of the speeds in high range. Low range gear ratios are approximately half that of high range.
When to use 4L:
on wet, slippery surfaces
passing through sandy areas
on rough trails
through shallow water
rock-climbing
climbing steep hills
through mud
descending steep hills
kakalito kasi sabi sa page 2.
Part-time 4WD refers to a vehicle with selectable 4x4 or 4x2, requiring the driver to manually shift between 2WD and 4WD using either a lever or a switch. With part-time 4WD, you can "shift on the fly" (switch between 2WD and 4WD while driving). Part-time 4WD gives you better traction on slippery surfaces because the front and rear sets of wheels are locked together. Thus, this is the optimum choice for most off-road conditions.
IMPORTANT: Vehicles with part-time 4WD systems should not be driven on dry, smooth road surfaces when in 4WD mode, or you will soon be spending a lot of money on repairs.
August 20th, 2013 12:35 PM #4589
August 20th, 2013 12:45 PM #4590
I don't know why people continue to try and take Kennon Road from Rosario. Its perpetually being...
2023 Toyota Wigo
